I've seen great stuff foam sprayed into openings but I've never seen it applied in the attic this way. Any ideas as to why this would be sprayed here? The insulation was pulled up when I entered the attic otherwise I would not have seen this. It was sprayed in several areas throughout.
Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified |
What's that black stuff out at the eave?
One possibility, Looks like they added a nailer for the drywall to the side of the truss/joist. Great stuff is an awesome drywall glue, perhaps this was a fast remedy to needing something to nail to. If you have a 12' 1" room and 12' drywall, and missed the joist, this is a hokey but effective way to hold it still.
Is there a wall below it? Seen it used to fill air gaps to stop the chimney effect. If this is a manufactured home, they use it as drywall glue. some homes have NO screws in the drywall at all. Simply foam and go. Its actually very strong. |
I can only imagine it was sprayed in to seal air leaks...
Steven Waskewicz Rest Assured Inspection Services, LLC. 719-510-7703 mobile all the time 719-495-7166 Fax. s_waskewicz@msn.com HVAC Lic. #10722 EPA cert.544143239730 www.restassuredinspection.com NACHIiid=NACHI06032370 |
It was a manufactured home. Thanks for the information. Vince Santos
The product is made by DOW Chenical, and yes it is used in some factory built homes. Rock still needs to be screwed. spacing for screws are greater when they use this glue.
Thanks for the information guys.
Vince Santos
dgagneur is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm on my second modular home and both ceiligns were done this way.
Dave |
mjohnson6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is kinda cool. It supports the Foam securing theory.
http://www.youtube.com/watch?v=c3AD46HRW2A Last edited by mjohnson6; 11/14/08 at 11:53 PM.. Reason: format |
This one too in particular :57 seconds in. and 4:51
http://www.youtube.com/watch?v=iqP_giVcF9Y |
| And Now the Great Depression | jburkeson1 | Miscellaneous Discussion for Inspectors | 13 | 10/4/08 6:49 PM |
| Dr. Ron Paul - The Creation of the Second Great Depression | jburkeson1 | Miscellaneous Discussion for Inspectors | 0 | 9/26/08 1:10 PM |
| Concrete Foam Forms | rcooke | Structural Inspections | 13 | 2/3/08 5:28 PM |
| Great Lakes-East Chapter Dec. 2006 Success! | jsieg | Miscellaneous Discussion for Inspectors | 3 | 12/12/06 8:33 PM |
| Atlanta Seminar- Great Folks | pabernathy | Electrical Inspections | 1 | 11/19/06 6:06 PM |
