Not an inspection question, this is just a problem in my house. The grout has cracked in several places in both the tiled showers in my house. Mainly in the corners of the shower walls.
There is a little movement in the foundation due to drainage issues that are being resolved, but the grout has been cracking in the past 6 months or so. I'm planning on renovating the master shower/tile in the next year or so, so I just wanted a quick fix. I cleaned out the grout that was cracking in the corners of the shower and replaced it with silicone caulking. When I removed the grout it comes out pretty easy in places. Even flakes off if you scrape it with a fingernail in areas that aren't cracked. This crack is continuing down from the drywall (if you can see it) down through the grout on the second floor. ![]() I haven't done a lot of tile and grout work. Best way to repair? John Safstrom TREC #10566 Systematic Home Inspections, PLLC Allen,TXwww.systematichomeinspections.com john@systematichomeinspections.com |
| Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Fiberglass shower pan.
Gary Oleski Home Inspections Home Inspections Connecticut Connecticut . 06610 NACHI04012833 CT#HOI.341 C M I
Silicone is flexible so that should work.
They also make a tape like silicone that is wide enough to cover gaps. Otherwise there are not to many alternatives that do not involve removing or covering the shower wall with a surround. |
HEY John, I am a tile guy, in my other life. Corners are notorious for cracking unless they are caulked. That is unsanded grout and it has a tendency to flake out, usually can be removed easily with utility knife. You can silicone the corners(which sounds like what you have done) and regrout the rest. If you want to do more you could regrout with Laticrete Permacolor grout. Regrouting with caulk or silicone will take a long time and probably not worth it.
Jim |
It could be a systemic problem with the grout itself. Grout that is not allowed to cure properly before being sealed (3 days min, even up to 7 days) or applied with too much water on the grout sponge will be weak and crack.
If you think it is a grout problem, remove the old grout, properly reapply the grout and seal it. Jeff T Licensed Home Inspector, HI-88 www.beachsideinspection.com www.cocoabeachhomeinspectors.com Serving all of Brevard County Florida including Cape Canaveral, Merritt Island, Cocoa Beach, Satellite Beach, Indialantic, Indian Harbour Beach, Melborne Beach, Mebourne, Viera, Palm Bay |
Yep
Throw water on the grout and see if it changes color to know if it is sealed. |
Jim is right, tiled corners are notorious for cracking. Unless you have a waterproof membrane system behind the tile, it could turn into a problem.
Silicone it after you have removed the loose grout and regrouted fresh. Clear silicone or get a silicone match for the color. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Great! Thanks for the replies - I guess I was on the right track after all with the silicone.
And yes the grout turns dark instantly when it gets wet. Is it too late to seal the grout that is already there? Built 2004. Quote:
Sell the house!!
John you can reseal the grout any time. Most sealer manufacturers recommend sealing every few years. Make sure to follow directions on bottle, and have fun.
I've confidently used the sanded/unsanded tile caulk products at all corner and floor to wall joints... silicone, IMO, looks like Harry Homeowner crap.
The tile caulk products are desinged for these areas and shouldn't give you *as much* trouble.. In a vanilla white unsanded install, *maybe* silicone looks OK, other than that, do it right You can find some at big box stores like http://www.homedepot.com/buy/paint/c...nen-96285.html or DAL tile or your local Tile supply house. Good luck |
I agree Tim; Any time that two areas of tile join each other in a 90-degree angle, particularly at horizontal planes, caulk needs to be inserted in place of grout as a joint filler. Simply purchase caulk which matches the color and texture of the grout to ensure a cohesive look. For example, if white, sanded grout is used on the wall tile of a shower, white, sanded caulk should be used in the join between the shower walls and floor. Tile caulk is an important part of nearly every wall tile, glass tile and shower tile application. Utilizing this material will help keep the tile job looking great for years to come, while protecting walls and floors from water damage. Use tile caulk the next time a tile installation is undertaken and know that the tile job is built to last. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Lynn Quo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are you saying that after regrouting that corner, that a 100% silicone caulk should be applied afterwards? |
| San Francisco Appliance, Air Conditioning and Heating Repair | Ron Casey | General Inspection Discussion | 0 | 5/11/08 1:48 PM |
| Phoenix Appliance, Air Conditioning, Heating and Repair | Scott P. Corsley | General Inspection Discussion | 1 | 5/1/08 6:34 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
