Customer asked me if the hardwood floor was sealed ?
Anybody know what she was talking abt ?
Lacquered, varnished, shellacked and untreated floors: Although technically surface finishes, lacquers, varnishes and shellacs are not as resistant to moisture, spills and wear as the other sealants mentioned. Treat floors with these finishes and floors with no finish as you would penetrating-seal-treated and oil-treated floors. Not sure what kind of finish you have? To tell the difference in a pinch, just rub your finger across the floor. If no smudge appears, the floor is surface sealed. If you do create a smudge, the floor has been treated with a penetrating seal, oil finish, shellac, varnish or lacquer, and then waxed. Robert Newland Tyrone, GA 30290 NACHI05101290 http://www.CertifiedHI.com http://www.HomeInspectorTyroneGa.com Home Inspection Reports Powered by: HomeGauge eServices |
appears to be an interlocking manufactured flooring, floating on pad or glue down, based on edge beveling and spills will enter easily at these edges.
try this for more info on wood flooring ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
thanks everybody
| Buckling of a Hardwood Floor | mcyr | Interior Inspections | 15 | 10/25/08 8:46 PM |
| Hardwood Flooring | jhagarty | Interior Inspections | 17 | 5/16/07 7:38 PM |
| hardwood flooring | cfuoco | Miscellaneous Discussion for Inspectors | 3 | 1/13/06 11:04 AM |
