Old 12/19/08, 11:44 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Default Hearth Extension Proper?
This new home has a change in color of tile for the hearth however no difference in elevation. Is this acceptable?
Thanks..
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 12/19/08, 11:47 PM
Chuck Evans's Avatar
Default Re: Hearth Extension Proper?
Tile is not flammable regardless of the color. projection of the sides appears to exceed the 1/8 inch per 1 inch rule though.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 12/19/08, 11:49 PM
Jeffrey R. Pope's Avatar
Yes, it's proper. The rule states that "the hearth extension shall be readily distinguishable from the surrounding floor."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Hearth size??? jcampbell Inspecting HVAC Systems 32 6/1/08 1:56 PM
Electricians Check List pabernathy Electrical Inspections 74 12/5/07 6:39 PM
Joe F, update? jtedesco1 Electrical Inspections 54 4/10/06 10:35 AM
