If I remember correctly a fireplace hearth should be min. 16" deep and min. 8" beyond each side. Question: Can these measurements be less if the fireplace has a permanently installed set of vented gas logs?
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You are correct about the 16 & 8; I did not see anything about being less if was vented gas logs. I did not dig into the code book, but I'm sure somebody will be able to help you.
If more than 6 sq. ft., then it needs 20" and 12". What do you mean by pemanently installed gas logs? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
How do gas logs get installed "permanently"?
Ok guys... Let's not get too hung up on the word permanent. LOL
So, then, you can't really consider whether or not gas logs are present if the fireplace was designed to burn combustible materials. Anyone can remove the gas logs and put some wood in it.
I would just refer to as when inspected Joe is right logs can be removed . If non vent log was present when inspected . that is what was inspected.
Just put in if fireplace is going to used other than non Vented logs. further evaluation must be done. And Modification may be required to bring it todays standards. Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
Nick around here New homes do not even have hearth. with gas logs.
prichardson is a non-member guest and is in no way affiliated with InterNACHI or its members.
If firebox is manufactured for gas logs it does not require a hearth. If firebox is manufactured for wood burning or both gas logs or wood burning it must have a hearth area that meets code.
Heatilator gas fireplace,
Page 9 and 10 HEARTH (not required) http://www.hpba.org/consumers/hearth/gas-logs Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Although this Standard applies to both commercial and residential fireplaces and chimneys, this Standard exceeds the requirements of both InterNACHI’s Commercial and Residential Standards of Practices. The inspection shall include examination of readily accessible and visible portions of solid-fuel-burning, low-heat fireplaces and chimneys. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Correct. The idea is to charge extra for it as an ancillary add-on inspection. The free checklist reporting form is just below the standard.
| Hearth size??? | jcampbell | Inspecting HVAC Systems | 32 | 6/1/08 1:56 PM |
| Question for all... | Bob Hopton-Jones | General Inspection Discussion | 9 | 4/6/07 7:43 AM |
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing Inspections | 4 | 3/20/07 11:56 PM |
