| Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera. |
This is a repost.
Today I inspected a cathedral ceiling on an addition that wasbuilt 8 mo. ago. There is a hole in the ceiling allowing me to see up in the cavity. The roof was constructed in the following layers from the outside-in: 25 year 3 tab shingles tar paper 5/8" plywood sheathing 1" foamboard (nailed between the joists, to the underside of sheathing Dura vent air spacer (the styrofoam ones that help maintain the gap) R 30 insulation w' kraft face 3/4" T & G pine planking My concerns are as follows: 1. The dura vent isnt under the roof sheathing, its under the foam board. The cold airflow doesn't run along the underside of the roof sheathing, it runs under the foamboard. Isn't this a double vapor barrier that might catch moisture and create a slew of problems? 2. The location of the foam board wouldnt seem to increase the "R" value since there is a stream of cold air on the under (interior) side of it. 3. The T & G has many gaps and spaces that is allowing heat & moisture into the cavities and has caused major ice dams and leaks. Shouldnt there be a poly vapor barrier or drywall under the t & G pine planking? Help... and thanks. Rick |
Depending on the type of styrofoam used, some do have characteristics of a vapor barrier, thus it could be considered as doubled. If I'm reading it right, the kraft face paper is your vapor barrier and would not require additional plastic under the t&g ceiling.
Bobby Hamilton Bloodhound Home Investigations Youngstown Home Inspection Austintown Ohio Home Inspection Youngstown Home Inspector Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Thanks for helping out. I agree about the kraft paper. I would like to have seen no kraft and poly completely sealing it up to prevent all moisture infilltration through the T & G. Has anyone ever seen this before? Really appreciate any input that anyone has.
| Vermiculite Insulation Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Services & Additional Topics | 3 | 1/10/09 9:43 PM |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Services & Additional Topics | 12 | 2/13/08 12:33 PM |
| Consumer needs help with missing insulation. | gromicko | Interior | 4 | 2/25/07 7:13 PM |
| Insulation blankets | rray | Plumbing | 30 | 12/9/06 10:38 AM |
