Old 11/7/11, 10:59 PM
Nick Gromicko's Avatar
Default Help with stove top / microwave distance. Narrative suggestions please.
13.5 inches between stove top and microwave bottom:
help-stove-top-microwave-distance-narrative-suggestions-please-stovetop-microwave-distance.jpg
Find a Home Inspector
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/7/11, 11:14 PM
James H. Bushart's Avatar
Default Re: Help with stove top / microwave distance. Narrative suggestions please.
Refer to manufacturer's instructions, first.
Go from there.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 11/7/11, 11:15 PM
William T. Misegades William T. Misegades is offline
Recommend having short buyers...
Most likely recommend removing the microwave.
Where there is a Will there is a Way!
Will Misegades
TREC# 10465
RedFish Home Inspections
www.redfishinspections.com
Old 11/7/11, 11:30 PM
Christopher Currins's Avatar
What JB said. Refer to manufacturer instructions.
Christopher Currins
Certified, Licensed
Old 11/7/11, 11:43 PM
I don't care what the manufacturer says. I'd call that a hazardous installation and a fire hazard.
"The microwave had inadequate clearance from the range-top burners. This condition will interfere with cooking operations and may be a potential fire hazard. The Inspector recommends correction by a qualified contractor."
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 11/8/11, 1:22 AM
Gary D. Rowden Gary D. Rowden is offline
The 13.5” clearance between stovetop and over the range microwave is to close and may be a potential fire hazard. Typically the manufacturer’s installation instructions on most over the range microwaves specify a 16” minimum clearance above stovetop. Recommend further evaluation and correction by a qualified licensed contractor.
Old 11/8/11, 5:14 AM
Russel Ray's Avatar
A couple of years ago I had a microwave that was 10˝" from burner to bottom of microwave. I mentioned it to my Clients and told them that I would check the Internet to see if I could find the installation instructions but that I doubted 10˝" was okay. Well, 10˝" actually was okay. That's the lowest clearance that I've ever found.
Old 11/8/11, 6:45 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
I agree with Kenton and would report the same way. You do not need to see the recommended distance if you can explain the common problem to your client. Some manufactures want it closer to the elements to provide better performance of the vent unit designed into the microwave.
We are concerned with SAFETY.
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/8/11, 7:44 AM
Jeffrey R. Jonas's Avatar
If this were my inspection, I would begin my research with the manufacturer of the convection oven, as there is no microwave pictured.
(I may be an ***, but my clients love me for my attention to detail).
Old 11/8/11, 8:50 AM
Marcel Gratton's Avatar
Below copied from the National Building Code (Canada); most likely it would be similar in the US.
1) Except as provided in Sentence (2), framing, finishes and cabinetry installed directly above the location of the range shall be not less than 750 mm (29.5 inches) above the level of range burners or elements.
2) The vertical clearance described in Sentence 1) for framing, finishes and cabinets located directly above the location of the range may be reduced to 600mm ((24 inches) above the level of the elements or burners provided the framing, finishes and cabinets
a) are noncombustible, or
b) are protected by
i) asbestos millboard not less than 6 mm thick, covered with sheet metal not less than 0.33 mm thick, or
ii) a metal hood with a 125 mm (5 inch) projection beyond the framing, finishes and cabinets.
On The Level Inspection
Gatineau, Québec
Old 11/8/11, 9:11 AM
KEVIN WOOD's Avatar
Nick can't you tell that is not a microwave. It is written on the pic. LOL
LG Electronics Over-the-Range Convection Microwave LMVH1750ST Review and Prices
The LG Over-the-Range Convection Microwave LMVH1750ST with its many advanced features, will quickly become the cooking tool of choice in your kitchen. Read Consumer Guide's review....
Read Full Expert Review
Stores Selling: 1
$629.00 - $629.00
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/24/11, 8:50 AM
Barry Adair's Avatar
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/24/11, 10:12 AM
Lacking specific code for this situation, most building inspectors would require the microwave be installed per the manufacturer's instructions. With that said...most instructions have minimum heights as shown in the attached picture below. Remember, those are minimum heights, and your cabinets, if any, should be built to this specification. If you were to use these minimum heights, and using the typical microwave height of 16-17", you would have a 13-14" clearance from the top of the range to the bottom of the microwave. This doesn't seem like much, but may be a good height for you, since you'll be lifting things into the microwave. Though it may be to low, because 13-14" wont accommodate some larger pots.
Basically, the manufactures recommended installation heights do not make any sense due to the different heights of microwaves and convection ovens.
It appears to be a standard Boiler Plate detail that they all use.
If you look at most installations in pictures, books, and lumber yard displays, you will notice that the bottom of the microwave is about 1 down from the bottom of the cabinets.
This dictates that the height would be 17" off the top of the range.
This never coincides with the manufactures detail for mounting height of 30" to the top or 66".
Old 12/24/11, 11:18 AM
clambert2 clambert2 is offline
Please Note: clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Kenton and Kevin,
If the manufacturer allows the close clearance then who are you to say they are a fire hazard? Who gave you the almighty power to circumvent them?
Your I don't care it is a fire hazard attitude just kills me, actually it it quite comical
Old 12/24/11, 11:20 AM
O yeah is metal combustible?
Suggestions? jknapp1 Miscellaneous Discussion for Inspectors 8 10/13/11 12:03 AM
