Old 10/25/09, 10:49 AM
John Evans John Evans is offline
Default Hiding Behind Insulation
It is amazing how many times I find water damage hidden behind rim joist insulation. Looking at the photos, you can see previous repair attempts, including a pound of caulking! Certainly recommend close inspection of joist bays if accessable. Especially below doors and at deck ledger boards.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Find an InterNACHI certified South Carolina Home Inspector (and anywhere else in North America)
Old 10/25/09, 10:55 AM
Default Re: Hiding Behind Insulation
Originally Posted by jevans View Post
Certainly recommend close inspection... Especially below doors and at deck ledger boards.
Those of us that have repaired much ill installed door and deck ledger damage are right there with you.
Larry Kage, CMI
231 929 3525
Old 10/25/09, 12:00 PM
Billy Boerner's Avatar
Billy Boerner Billy Boerner is offline
Send a message via Yahoo to bboerner
Good catch John. I always make sure to move all rim joist installation. This part of the inspection is when I'm thankful that I'm 6'5.
Bill Boerner
STL Home Inspection Services
Serving St. Louis/Surrounding
(314) 805-2137
billy.boerner@gmail.com
http://www.stlhomeinspector.com
Old 10/25/09, 1:24 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Nice find John. I like it when you find this also.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 10/25/09, 1:31 PM
Good find, and something not to forget.
That house must have been built in the mid 80's from the look of things.
Old 10/25/09, 2:09 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is online now
From an inspection this week.
Old 10/25/09, 2:35 PM
Mike, any idea what cause the leak? Door above, entrance porch slab, deck ledger?
It won't be long with this wafer junk, you can see where the glue joint is letting go on that I-joist.
Old 10/25/09, 2:47 PM
Michael Larson's Avatar
You're not serious, right?
I could see it maybe under doors but ALL of it?
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 10/25/09, 3:43 PM
Yes sir I'm serious I look behind all of it.
Bill Boerner
(314) 805-2137
Old 10/26/09, 7:52 AM
Joshua L. Frederick Joshua L. Frederick is offline
.... this part of the inspection is when I'm thankful that I'm 6'5.
Must not have too many crawlspaces over your way, eh?
Old 10/26/09, 9:29 AM
I try to inspect joist bays that are below doors and connected to deck ledgers. It would take too much time to remove insulation at every accessible bay.
Old 10/26/09, 10:18 AM
Synopsis:
Beautiful maintenance free deck built with the house in '02 using a trex or similar product. House is virtually unlived in, built by an older couple. The deck "boards" swelled up, and didnt allow drainage, which around here means with rain/snow/freeze/thaw = large piles of snow and ice on the deck, and tremendous weight added. The deck now pools water, about 1/4 inch. Had it been built poorly, it would be worse, but it is built with 2x10's, with more than adequate support, just not enough to handle the thousands of pounds of snow times many winters. This backed up water against the house, and it found a way in. This is near the middle of the deck, and my guess is this is where the flashing is lapped, it was only showing moisture damage here, not the whole length. This is the Eave end of the house, with no gutters above it, so between the square footage of the deck plus the roof, there has been lots of water pouring on the deck.
Old 10/26/09, 11:09 AM
Good synopsis Mike. That explains it. That is why when I build a deck like that, I first cover the top of the ledger board with vycor flashing and then install the copper or plastic L flashing and then flash it again with a vycor flashing on the vertical wall with the WRB draped on top of that. Prooves good for that kind of water intrusions at the lap joints.
Wasn't there a gap between the deck boards if this was composite decking?
That stuff will expand up to 1/2" in twenty feet and 1/8" width wise.
But when it is cold it shrinks, so you would think the gaps created would provide the proper drainage to prevent ice buildup.
Just a question I guess. I'm a fanatic when it comes to what caused it.
Thanks for your explanation. Good points to remember when we look at decks, and more reason to check inbetween the joist and band joist when accessible.
Old 10/26/09, 2:19 PM
There have been a number of defective maintenance free decking that inst supposed to swell that did. I know one house that the decking was replaced free of charge because it held water. The Hot/cold does cause expansion/contraction, but the defective ones swelled due to moisture. Some if the plastic "boards" use wood fiber as a filler that eventually swelled.
Old 10/26/09, 3:03 PM
Thanks
Hopefully, I don't come across that product, for someone will hear about it.
Insulating Your House from CMHC mkyriacou Canadian Inspectors 10 2/14/10 4:50 PM
Thermal insulation research for sustainable construction mkyriacou Green Building Inspections 0 3/3/09 12:04 AM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 2:30 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 6:25 PM
