| Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera. |
The Realtor did not understand what was wrong?
"Never ever threaten anyone in Camoflage" Tim Wilson "Not everyone follows the same path" Governor Sanford, musings on the Appalachian Trail
Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
It looks like one of those faucets that you can pull out and use as a handheld. That's probably why they put that type in, so they can rinse the other sink out.
It is one of those things that as soon as someone moves in and realizes what is going on, they call the lame *** HI and start whinning. </IMG></IMG></IMG></IMG></IMG> "Never ever threaten anyone in Camoflage" Tim Wilson "Not everyone follows the same path" Governor Sanford, musings on the Appalachian Trail
is in order?............. Or. Recomiendo a idiota que instaló esta reparación él correctamente. |
Two position-full flood or full spray. Make sure that the weight is present so that it will retract properly. Twice in new construction (out of five) they were not added. The joint is about 3" from the base of the arm. T.Neyedli www.alphahominspections.ca |
ccurrins is a non-member guest and is in no way affiliated with InterNACHI or its members.
Justy pull the spray head out and it will reach just fine
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
Maybe they just wanted to keep the sink divider clean.
wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
I was looking through some websites and I think that they probably have the wrong faucet installed as the base of this one would extend inappropriately over the basin on this type of sink. They must have placed it in the incorrect hole because of this rather than purchasing an appropriate faucet.
See the sink on the right: http://www.luxuryplumbingplus.com/Sh...tainless-Steel Last edited by wforsyth; 3/14/07 at 1:53 PM.. |
Another hmmm.
When I reported a leak from a second story shower, in a tub/shower, the realtor and the seller both assured me that no one uses the the second story shower, and that anyone wanting a shower would use the stall shower on the ground floor. I was dumfounded. InterNACHI Vice President, InterNACHI Editor-in-Chief, co-founder CalNACHI Author of Manual For a Happy Home & Inspect & Protect |
Good Lord! No one uses the second story shower? In THEIR family! They don't think maybe the buyer might want the OPTION of using the second shower?
Amazing! I just talked to someone who used the inspector that the REALTOR recommended. They ended up buying a house with no ventilation, only into the attic, drenched insulation, black mold throughout the house, false drop down ceiling to hide moisture issues, slumping house in the corner, water everywhere, water stains painted over above all the windows upstairs, new carpet laid OVER the trim and when lifted (easy because not tacked down) found mold and sopping wet subflooring...it goes on and on. The inspector that was referred by the realtor? Used a checklist along the lines of A NA R ? and then Roof with a checkmark in the appropriate box. There was NO information included along with the report. Nothing stating what room or system was being discussed, no mention of moisture, mold, lack of GFCI's, failing roof, no gutters downspouts, etc...etc... These people have three little girls and they are ALL sick! They just moved in two weeks ago, and they have to stay in a hotel now. Grrrrrrrrrrr...... |
What's wrong ???
Well for starters you need a napkin under that cup.... Mic Physical strength can never permanently withstand the impact of spiritual force. FRANKLIN D. ROOSEVELT 32nd U.S. President |
Hey wendy isn't it true that the inspector that did the inspection and the realtor will both be held responsbile!!!! or at least liable.
frank www.afrankinspection.com |
