Old 2/28/08, 8:14 PM
David K. Lee David K. Lee is offline
Default Hole in attic
Found a hole in the wall in the attic. Unit is a townhouse and I believe it is a firewall. How would you write this?
Old 2/29/08, 12:36 PM
Default Re: Hole in attic
If it's a partition wall between two townhomes, it's pretty simple.
"A hole was found in the partition wall between the townhomes. This wall is a fire separation wall. The hole should be repaired."
Abraham Lincoln
Old 3/6/08, 9:29 AM
Allen L. Catterton's Avatar
Allen L. Catterton Allen L. Catterton is offline
I see this fairly regularly at multiplex units and town houses in this area. It is a convenient way that your neighbor has found to break into your home through the attic and steal you TV. Call it out as a defective fire wall that needs repair.
Truss Uplift rcooke Canadian Inspectors 5 2/26/08 8:43 PM
Attic Temps mroe Miscellaneous Discussion for Inspectors 12 8/26/07 10:32 AM
Spray Foam to the Rescue ? mcyr Structural Inspections 3 3/27/07 8:29 PM
Attic Inspection rbritton Electrical Inspections 19 8/2/06 3:58 PM
