The door in the picture leads from a basement garage into a entertainment room which also has a bathroom that also has a door that exits into the basement garage. This is a hollow core door. The door that leads to the stairway up to the main living area was a fire rated door but not these other two doors. I felt like these should be fire rated doors as well. Am i wrong.
This Door Should Be Fire Rated As Well
lcapaul is a non-member guest and is in no way affiliated with InterNACHI or its members.
True But Not I Florida
Up in our neck of the woods...Fire-rated metal clad, self-closing door as well.
Darrell Hadler CMI Five Star Home Inspections Medicine Hat, AB. Canada NACHI# 04111082 Cell phone# (403)502-3593 Inspected once . . . inspected right! (website) http://inspectorpages.com/dhadler
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
If the stairway corridor is rated properly, only the door at the top of the stairs needs to be fire rated. Otherwise, only the first door from the garage needs to be fire rated.
The self-closing requirement only applies in jurisdictions where the UBC is enforced. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
This door I'm speaking of is to a room that is in the basement garage. There is a separate door that leads to the stairway up to the main floor.
Are you sure the door isn't fire rated? Some hollow core doors are.
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Well no I am not. There was nothing on the door to determine whether it was or not.
It is supposed to be rated, so recommend verification.
Thanks, That what I will do.
I'm surprised. Here in Ontario it doesn't have to be fire rated. Self closing yes. But this is for fumes and gases only. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
They also require gaskets all the way around .
Code I do not do code but safty yes they should all be self closing . Some people have cars like me with keyless starting, lean up against the counter and you could kill every one in the home . Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
| Bedroom Door leading to garage | jberthiaume | Interior Inspections | 31 | 6/23/10 7:57 PM |
| Evaporative cooler in garage | chellickson | Inspecting HVAC Systems | 9 | 7/23/07 1:08 AM |
| Garage ceiling & door header | Al Barb | Interior Inspections | 7 | 3/27/07 1:07 PM |
| hollow core exterior doors | gkoehl | Exterior Inspections | 16 | 3/12/07 10:52 PM |
