what causes this?
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Defrost heater may be stuck on
Its the mullion strip...Every notice that button or switch that says..ENERGY SAVER? That button actually sends heat to the little rubber mullion strip to prevent condensation from forming. 133 degrees is excessive but is that temp gun accurate? So it could be operating as intended. Try shutting that "Energy saver" button off for a bit to see if it will reset the strip. Empty refrigerator means that its been sitting for some time. Mullion strips can do that if not used. Door may have been closed for weeks, without opening...
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Easy test. Record the temperature of boiling water. Should be about 212.
Good one Joe.....thanks for the tip
Then you can work on emissivity, specular and diffuse reflection, ambient temps, temp reflect, and distance ratio of the device....
Or, you can just note that it is in fact working or not... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Thanks guys, it was an reo and it was the first time the unit had been on in months. When I leaned in to record the age of the unit I felt the heat. 1 hour later as I was shutting every down it had cooled off.
www.MauiHomeInspections.com |
Condenser fan? Or clogged/dirty coils?
Have seen outer frames of refrigerators as well as the mullion get warm... very warm from that same thing. 6-7 years ago I had a side by side that was doing that very same thing and my wife mentioned what was going on.. I said " I don't have time... call an appliance guy" $25 Condenser fan from Johnstone... nearly $500 repair I ran into him later... I got the last laugh. In retrospect, I have learned that... sometimes when people offer tips... you may be *over charging* and they're pissed. |
| Refrigerator recall due to fire hazard | mlarson | General Inspection Discussion | 7 | 2/28/12 11:43 PM |
| Refrigerator Water Dispenser Works Only Intermittently | Matt Ablemarle | Plumbing Inspections | 3 | 2/28/12 3:27 PM |
| Dedicated breakers (washing machine, microwave, refrigerator) | jfrederick | Electrical Inspections | 6 | 2/20/10 1:14 PM |
| Refrigerator Temperature Range | wrosario | Interior Inspections | 5 | 7/22/06 1:52 AM |
