Old 4/25/11, 1:14 PM
tcomstock tcomstock is offline
Default Houston, Texas - Self Closing Hinges
I have been told by a Houston City Inspector and by a Building Supervisor for a large building company that self closing hinges are required on the pedestrian door into the garage, either within city limits, or within the county. This must be a local code, but I can not find this code anywhere. Does anyone know if this exists and if so, where can I find it?
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/25/11, 1:49 PM
Tom Leahy Tom Leahy is offline
Default Re: Houston, Texas - Self Closing Hinges
The code was deleted from the IRC (not sure when). Still could be a local code. I believe it's still in the IBC. I still write it up as a recommended improvement to maintain the fire separation and prevent fumes from entering the living area. Strictly a safety issue from my point of view regardless of the code. I just explain why and go on
Fort Worth Home Inspector
Dallas Home Inspector
Old 4/25/11, 2:54 PM
Jeffrey R. Jonas's Avatar
Exactly... safety issue... screw the code.
Answer via a question... If you have one on your home, (now that the "code" has been removed), would you remove the self-closer?
I didn't think so.
Old 4/25/11, 3:35 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
It will not hurt to tell them the man door may not be fire rated if no plate can be found on the frame and explain why this is good to have.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/25/11, 7:12 PM
Banned
Kevin:
You seem to be stuck on having a fire rated person door from the garage to the house yet not required in single family dwellings by Canadian codes......yes, you can always do better than codes but I believe there are better things to do in houses like an interconnected system of smoke detectors with integral battery back-up. Sometimes I recommend up to 5-6 in a house depending on its layout, location of laundry, elect panel, heating equipment.
(NOTE: I used to teach part of the WETT course here with a Deputy Fire Marshall who now works privately as a consultant in the insurance industry and developed some of my ideas from discussons with him)
See where and why fires occur here:
http://nfpaweb2.gvpi.net:8089/assets...reOverview.pdf
Old 4/25/11, 7:39 PM
Chuck Evans's Avatar
R309.1 Opening protection. Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openings between the garage and residence shall be equipped with solid wood doors not less than 1 3/8 inches (35 mm) in thickness, solid or honeycomb core steel doors not less than 1 3/8 inches (35 mm) thick, or 20-minute fire-rated doors all of which shall be self-closing.
The source: Houston Amendments to the 2006 International Residential Code
http://documents.publicworks.houston...s_to_06irc.pdf
I'm not aware of any similar requirement in the counties.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 4/25/11, 8:01 PM
KEVIN WOOD's Avatar
I also taught the WETT wood portion of the course that was in the Carson Dunlop Home Inspection at "Sault College" I went to the "Site Basic" in Sudbury and was so upset at the waste of my time that I am no longer endorsing a WETT Inspection and will not list my name.
As for your comment about where fires come from. I would not care if only one fire started in the garage and the door gave the individual family time to escape through the corridor to the front door. This would be enough for me to make that recommendation.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/25/11, 8:28 PM
KEVIN WOOD's Avatar
WOOPS!
I forgot to add this Brian
www.nachi.org/attached-garage-fire-hazards.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/25/11, 11:33 PM
Thank you Chuck,, That is exactly what I was looking for!
Old 4/25/11, 11:34 PM
Banned
I also taught the WETT wood portion of the course that was in the Carson Dunlop Home Inspection (as far as I know, CD may mention WETT but don't instruct in WETT) at "Sault College" I went to the "Sight Basic" (SITE Basic) in Sudbury and was so upset at the waist (waste) of my time that I am no longer indorsing (endorsing) a WETT Inspection and will not list my name.
My comment about teaching WETT was more directed towards side/lunch discussions with the Deputy Fire Marshall who was the main instructor. He brought me into every course over 8-10 years to do my version of the "house-as-a-system" which by-the-way has evolved and is now 2 separate WETT courses-"Testing and Managing House Pressures" and "Smoke Spillage Prevention". Have been WETT-certified Master since 1988 (one of the first group of 13 Masters) and was WETT National Board member/ head of education committee.
From that article...stating the obvious:
"Fires that begin in attached garages are more likely to spread to living areas than fires that originate in detached garages."
Our garages tend to be much different than mid to southern US garages with the DHW heater and heating equipment installed within.
In 99.5+% of garages I inspect, the door is 1+3/8" steel skinned which must be considered close to an equivalent of the 20 minute rated door......From the code quote in the article:
"Other openings between the garage and the residence shall be equipped with solid wood doors not less than 1-3/8” (35 mm) in thickness, solid- or honeycomb-core steel doors not less than 1-3/8” (35 mm) thick, or 20-minute fire-rated doors."
Just because a door does not have the "fire rating" metal decal on it does not mean it does not have the ability to stop fire.
This is the final line:
"In summary, attached garages should be sealed off from the living space so that fire may be contained."
This is what our codes achieve!!
"I am such a safety oriented individual that my wife says I am paranoid."
IMHO, as HI's, we should not be passing excesses on to the customer!!
Old 4/26/11, 3:41 AM
KEVIN WOOD's Avatar
HAPPY!
If you look into the back of the Carson Dunlop book on Heating two.
You will find what portion was on WETT.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/26/11, 3:54 AM
KEVIN WOOD's Avatar
Kevin:
I don't like to correct everyone.
But if you are going to correct someone correct your own thinking.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 4/26/11, 5:44 AM
Banned
HAPPY!
So by taking the CD course, do persons become WETT certified?
Old 4/26/11, 8:42 AM
KEVIN WOOD's Avatar
NOOOOOO WAAAAAY!
Not even after taking 40 Hrs of Heating two are they WETT certified or Home Inspection certified to inspect wood stoves or fireplaces.
The WETT certification requires field experience not just the schooling.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Home Inspection in Houston Texas zfackler General Inspection Discussion 24 11/1/09 6:33 PM
Wells, Water Quality, and Commercial Inspection Training - Houston, texas in Sept ! jfarsetta Ancillary Inspection Services & Additional Topics 0 8/21/08 1:20 PM
