Go Back   InterNACHI Message Board > Specific Inspection Topics > Interior
Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera.
Old 6/22/09, 11:45 PM
Gregory A. Liebig's Avatar
Gregory A. Liebig Gregory A. Liebig is offline
Default Indoor BBQ
In the late 50's and especially in the 60's there were many homes built with Brat Grills (indoor BBQ's) in basements around here. As one can imagine, they were mostly fired with Charcoal which is an excellent way to suck the oxygen out of a home. Even more so, none have an external air intake and many of the old basement windows have been converted from wood or aluminum hopper to glass block without vents.
What would be some of your suggestions for commenting on an item like this in your report that you would present to your client? I did a search for "indoor bbq" but nothing came up.
Thanks for your help!
Greg Liebig, Owner
Sheboygan Wisconsin Home Inspector
4-Square Home Inspections, LLC
Where Knowlege will put your Mind at Ease ©
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Follow Us on Facebook
Follow Us on Linked-In
Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America)
Old 6/23/09, 2:02 AM
Joe Funderburk, CMI's Avatar
Default Re: Indoor BBQ
I've never seen anything like that. We cook our squirrels outside down here.
There is a flue on it, right? However, provided it has a flue, I don't see much difference between it and a fireplace. I don't think an air intake is an issue on an older home like what you describe. But the door does not opens over a hearth, which is a concern for me.
I would probably simply say it is old, unconventional and beyond my expertise and refer it to a fireplace specialist.
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/23/09, 7:20 AM
David P. Valley's Avatar
The hearth depth stands out like a soar thumb.
The following is on my inspection reports...
Recommend a Level II inspection prior to close of escrow (http://www.csia.org) * See Manual...page 13G & H
Old 6/23/09, 8:44 AM
Linda J. Foster's Avatar
Linda J. Foster Linda J. Foster is offline
Is there a brand name on those, anywhere?
Linda Foster
www.HomeInspectionsByFoster.com
HomeInspectionsByFoster@yahoo.com
(210) 347-1023
TREC #7654
InterNACHI #06032691
Old 6/23/09, 10:06 AM
No, there are no model numbers. They are custom built and there is a separate flue that usually is combined in the chimney with the furnace flue. I'm just curious about burning charcoal inside the dwelling since every bag of charcoal states not to do that.
I have not found anyone to use them, but there are plenty around here.
Greg Liebig, Owner
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Old 6/23/09, 10:27 AM
Michael Larson's Avatar
No different than a wood fired IMHO.
As for the charcoal bag warning, it's a lawyer label for idiots that might want to use their Weber inside.
"Never underestimate the difficulty of changing false beliefs by facts."
Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
or
Old 6/23/09, 4:13 PM
Mark Nahrgang's Avatar
Mark Nahrgang Mark Nahrgang is offline
Its a little different... If you are using natural charcoal it isn't, but the briquettes have some additional things added to them...coal, petroleum (as starter), and other things besides wood. I don't know if that has anything to do with it or not, but I wouldn't put kingsford in my fireplace.
I guess you've also got the possibility of the idiot using a whole can of lighter fluid and torching the whole basement.
Old 6/23/09, 4:33 PM
Patrick Carter's Avatar
Patrick Carter Patrick Carter is offline
This indoor BBQ was from a home I inspected in Oct of 2005 - The house was built in 1969...........
Old 6/23/09, 10:18 PM
Are you sure these things are not properly referred to as a Dutch Oven? Used for cooking bread?
Joe Funderburk, CMI
Old 6/23/09, 10:31 PM
A Quick Course on Dutch Ovens
Michael Larson
Hudson, WI
InspectraPro
or
Old 6/24/09, 12:32 AM
I used the wrong word. (But I didn't know a Dutch oven was just a pot!).
I was thinking more along these lines...a brick oven. I think it should be referred to as an oven, instead of an indoor BBQ, regardless.
Joe Funderburk, CMI
Old 6/24/09, 8:19 AM
Now this is cool, and this is absolutely something I would love to have in my home. Can you image the flavor of the bread or pizza you could make! Mmmmm. Yummy!
Old 6/30/09, 9:56 PM
Now that's a pizza oven!!
Greg Liebig, Owner
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Copyright © International Association of Certified Home Inspectors, Inc. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
