Old 9/18/10, 4:56 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default insulation between floors?
Did an inspection today on a 2 story house in which the space above the first floor (kitchen, living room, etc...) had no insulation. The attic upstairs had R-30 cellulose. What's the consensus on insulation between the first and second floor?
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/18/10, 6:28 PM
Default Re: insulation between floors?
It is not needed. That area is not part of the building envelope.
I suppose, for sound deadening, a case could be made.
Larry Kage, CMI
231 929 3525
Old 9/18/10, 7:57 PM
James F. McKee's Avatar
as Larry said only used for sound as in the case of rental unit separation....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 9/18/10, 8:54 PM
Agreed and as Jim pointed out for rental units, sometimes it is also wise to insulate the second floor to retain the heat on the first floor unit when the two apartments have seperate heating units, and responsible for their own heat.
One would be surprised at the heat loss from the first floor to the second.
Other than that, not required.
Old 9/18/10, 9:57 PM
Joe Funderburk, CMI's Avatar
Should there be insulation between interior walls?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/18/10, 10:01 PM
cboyd cboyd is offline
Please Note: cboyd is a non-member guest and is in no way affiliated with InterNACHI or its members.
"One would be surprised at the heat loss from the first floor to the second."
You got that right Marcel, we actually don't heat our second floor in my 140 year old farm house, it just sucks up the heat from the first floor and stays quite comfortable for the most part. I have to replace the heat on the first floor on a pretty regular basis though $$$
Old 9/18/10, 11:58 PM
Nick Gromicko's Avatar
In a home I built for myself, not only did I not insulate between the first and second floor, I didn't have any heating on the second floor at all. The second floor relied solely on the heat from the first floor rising.
Find a Home Inspector
Old 9/19/10, 10:35 AM
rspermo rspermo is offline
Please Note: rspermo is a non-member guest and is in no way affiliated with InterNACHI or its members.
While I agree you do not need to insulate between the floors you do need to have an air barrier and insulation at the end of the joists (rim board) to prevent air flow between the 2 floors.
Old 9/19/10, 11:02 AM
That is correct and seldom done in older homes. IR camera is about the only way to find out.
In the winter time, you could use an IR Thermometer also and shoot the ceiling perimeters and the field of the ceiling and walls for comparison.
Old 9/19/10, 8:42 PM
What kind of rooms did you have on the 2nd floor. By c^de, all habitable rooms are supposed to have a source of heat.
Theodore Roosevelt
Joe Funderburk, CMI
Old 9/19/10, 9:07 PM
Joe, it did, just not like you see it today. It had radiant floor heating.
He also probably had floor registers to radiate heat in the space like I had in my Fathers home back in the 50's till the mid 60's when it got changed to oil heat.
Met code back then. If there was one.
Old 9/19/10, 10:18 PM
I had all bedrooms upstairs. It violated code but I didn't care. It worked great.
Old 9/20/10, 10:14 AM
Roy D. Cooke, Sr's Avatar
Floor register to let the heat Up ???????
I thought these where so the Kids could lay on the floor and hear what mom ,dad and their friends where saying .
This was great place to hear all the stories they talked about .
Old 9/20/10, 10:22 AM
Yeah, you could hear if having to get a twitch in the woods was in the forecast for something you might have done wrong.
Worked great for heat too!, all the way from the wood furnance in the basement.
I got to be a pilot because of that wood furnance at a very young age.
Old 9/23/10, 2:06 PM
Originally Posted by lkage View Post
...I suppose, for sound deadening, a case could be made.
Sound travels through framing. Insulating walls and ceilings makes very little difference in lowering sound transfer. A long time ago I once recommended insulating between ceiling joists to lower sound levels. It made almost no difference and they were not happy with me.
Often when we framed library and sometimes bedroom walls, in each wall we used 2x6 top and bottom plates and two sets of 2x4 studs, each set held flush to opposite sides of the plates and each set offset from each other.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Insulating Your House from CMHC mkyriacou Canadian Inspectors 10 2/14/10 3:50 PM
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 10:49 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 5:25 PM
