These shots are from the attic of a five year old home. In one area, the fiberglas has been blown back by a gust of wind through the perforated aluminum soffit vents.
Obviously it needs to be redistributed, but if this was your home how would you prevent it from happening again? |
| Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
A gust of wind, from the soffit, should be directed up the proper vents (chute) and toward the ridge vent.
I can't really see the top of the exterior wall between the trusses but, often, a piece of batt insulation is stuffed there between the top plate and cardboard proper vent. Or, there are cardboard proper vents that sit tight to the exterior corner of the top plate to seal the soffit off so insulation doesn't fall into it. In your case it appears the air is not directed up the chute but, instead, blows on the insulation in that bay. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Hi Larry
I think the bay with the chute is working properly. It's the next bay over that's blowing. I like your idea of stuffing fiberglas in to prevent blowing. I have seen fiberglas batts in the location you suggest in other houses but I always figured it was just to keep the loose insulation out of the soffits. I guess it serves two purposes. |
The wax coated cardboard combination end baffle and air chute are a good solution if.......installed properly.......there's that old recurring problem again.......quality workmanship!!! The best way to solve that problem is at the framing/sheathing stage. Extend the sheathing to the top of the butt end of the raised heel truss so it forms a solid air barrier and directs wind up over the insulation. Last edited by Brian A. MacNeish; 4/16/10 at 7:57 PM.. |
| Question about exposed styrofoam insulation. | mlong | Exterior Inspections | 9 | 12/21/07 8:33 AM |
| Consumer needs help with missing insulation. | gromicko | Interior Inspections | 4 | 2/25/07 6:13 PM |
