Old 2/10/09, 4:22 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Default Insulation Pics
Does this look like vermiculite to you guys? This appeared to be mixed in with wool insulatin, like this was spread out over the top of it. Thanks.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/10/09, 6:58 PM
tneyedli1's Avatar
tneyedli1 tneyedli1 is offline
Please Note: tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Insulation Pics
Originally Posted by iniquette View Post
Attachment 26812
Attachment 26813
Attachment 26814
Ian:
It appears to be zonolite/vermiculite and shredded newspaper.This was touted an easy upgrade for the owner to do. I did this technique to my old home in 1979. The shredded newspaper was treated with borax to reduce fire and be rodent proof.
If I only knew then what I know now.....The common belief was that the homeowner added the shredded stuff to the original layer and then "fluffed" them up to add small airpockets, hence adding to the "R" value.
T.Neyedli
www.alphahomeinspections.ca
Old 2/10/09, 7:12 PM
iniquette's Avatar
Thanks Terry. I don't see this stuff too often, so I just wanted an extra opinion. looks like my initial hunch was correct.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/10/09, 7:25 PM
Rodney Misener's Avatar
Rodney Misener Rodney Misener is offline
Another good reason to wear a mask while in the attic...possible ACM.
Rodney Misener, CMI
Trinity Inspection Services
Pictou County, Nova Scotia
http://www.trinityinspectionservices.com
Certified Home Inspector
Certified Level 1 Thermographer
Certified Energy Advisor
WETT Certified Inspector
IAC2 Radon/Mold Certified
Infrared Certified
Old 2/12/09, 6:07 PM
pabrioux pabrioux is offline
That definetely looks like vemiculite, from what I can see.
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 11:49 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 2:30 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 6:25 PM
