A new condo with with 17" floor trusses between the first unit and the unit above. Can anyone tell me if 17" of loose fill fiber glass insulation will provide similar sound proof qualities as the same amount of fiber glass batts?
Is there a code that states how much insulation is required (zone 5 - Michigan) above the garage when the garage is located below a heated living area? Thank you, Kevin |
bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
For effective sound-proofing, insulation on it's own isn't enough. The ceiling joists between units should be strapped with resilient channel.
http://www.soundproofing.org/infopages/channel.htm Last edited by bjones1; 2/3/08 at 12:29 AM.. |
Thank you for the feedback!
Kevin Goff |
I believe that STC ratings that you are interested in might be found here.
bJones is on the right track. ![]() STC RATINGS FOR VARIOUS WALL ASSEMBLIES Below are the STC ratings of various wall assemblies, each presented to help illustrate concepts, improvements and rules of thumb. The estimated ratings are based on laboratory test results from various compendiums of STC ratings. It is recommended to consult a professional acoustician for more detailed information or to analyze the specifics of your project/assembly. To view different wall assemblies, click on each point below that may apply to your project. 1. Insulation will noticeably improve the STC rating of an assembly. 2. Staggered or double stud walls are higher rated than single stud walls. 3. Metal stud walls perform better than wood stud walls. 4. Resilient channel can improve the STC rating of an assembly. 5. Adding additional layers of drywall can improve the STC rating of an assembly. 6. Drywall between double studs can dramatically reduce the STC rating of an assembly. 1. Insulation will noticeably improve the STC rating of an assembly. Description Estimated STC RatingWall Assembly 3 5/8" metal studs, 5/8" gyp (2 layers total), No insulation 38 - 40 ![]() 3 5/8" metal studs, 5/8" gyp (2 layers total), Batt insulation 43 - 44 ![]() back to top 2. Staggered or double stud walls are higher rated than single stud walls. Description Estimated STC RatingWall Assembly 2x4 stud, 5/8" gyp (2 layers total), Batt insulation 34 - 39 ![]() Staggered studs, 5/8" gyp (2 layers total), Batt insulation 46 - 47 ![]() 2x4 studs, 5/8" gyp (2 layers total), Batt insulation 56 - 59 ![]() back to top 3. Metal stud walls perform better than wood stud walls. (NOTE: This only applies to single stud assemblies. For double stud assemblies, there is virtually no difference.) Description Estimated STC RatingWall Assembly 2x4 stud, 5/8" gyp (2 layers total), Batt insulation 34 - 39 ![]() 3 5/8" metal studs, 5/8" gyp (2 layers total), Batt insulation 43 - 44 ![]() back to top 4. Resilient channel can improve the STC rating of an assembly. (NOTE: These ratings are based on laboratory tests. Because of the special care required when installing resilient channels, actual results could be substantially lower.) Description Estimated STC RatingWall Assembly 2x4 stud, 5/8" gyp (2 layers total), Batt insulation 34 - 39 ![]() 2x4 stud, 5/8" gyp (2 layers total), Resilient Channel, Batt insulation 45 - 52 ![]() back to top 5. Adding additional layers of drywall can improve the STC rating of an assembly. Description Estimated STC Rating Wall Assembly 2x4 stud, 5/8" gyp (2 layers total), Batt insulation 34 - 39 ![]() 3 5/8" metal studs, 5/8" gyp (3 layers total), Batt insulation 39 - 40 ![]() 2x4 stud, 5/8" gyp (4 layers total), Batt insulation 43 - 45 ![]() back to top 6. Drywall between double studs can dramatically reduce the STC rating of an assembly. Description Estimated STC RatingWall Assembly 2x4 studs, 5/8" gyp (4 layers total), Batt insulation 44 - 45 ![]() 2x4 studs, 5/8" gyp (2 layers total), Batt insulation 56 - 59 ![]() 2x4 studs,5/8" gyp (3 layers total), Batt insulation 59 - 60 ![]() 2x4 studs, 5/8" gyp (4 layers total), Batt insulation 58 - 63 ![]() back to top Rules of Thumb Recommended Ratings Weaknesses - What You Should Know The difference between STC and NRC STC Ratings for Masonry Walls Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I've installed resilient channel on numerous occasions, going back 20 + years. In theory, with the channel, your drywall basically floats, away from the ceiling joists or wall studs. In a lot of the higher end homes, It's used on the walls separating the bathrooms. Guess they dont want to hear what's goin' on in there
I always thought it was for the Master bedroom walls.
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 7:45 PM |
| Vaulted Ceiling Insulation | rcooke | Canadian Inspectors | 3 | 1/22/07 11:24 AM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 6:25 PM |
| Crawlspace Insulation | gbrasseur | Structural Inspections | 12 | 12/3/06 4:18 PM |
