I don't believe I have ever come across this type of insulation, at least not in this form anyway. The home was build in the 40's with this insulation being on the walls. It looked like cardboard but was very thin and brittle.
Any idea what type it is? |
Vince,
I've run into this type of insulation many times here in my area. The thin brown layered insulation is simply a thin crepe paper they used many years ago. I only find it in the older homes. The insulation in your first pic in the upper right hand corner appears to be rock wool hanging out of the barrier. It's R-value needs upgrading either way. |
I have never seen it before, but that 3rd picture looks like a Hornet's nest.
I have seen similar products of the sort when I was a pompous kid. ha. ha.
While working with my father in the early 1960's, I used to pull it out of the wall and wondered why it had a paper on both sides. Back then, I called it bagged insulation, and had no idea what it's composition was nor do I today. Can't find any history on it. For obvious reasons, no computers right? Like Dave mentioned,. the paper was brittle and saw some with a cellulose type insulation and some with a fiber type. Called it rock wool. It was about 2" thick bagged. Stapled in the middle of the stud creating two air space. Marcel </IMG> LEED Green Associates Inachi US Member of the Year Award 2009 Best Home Inspector Software http://co.nachi.org/inachiawards |
As D Valley said the first picture does appear to have an early rockwool hanging from the batt. |
Today... they use it for Electrical insulators, but yesteryear they used it as residential insulation. Check it out here. When this stuff gets old, it becomes brittle and crumbles and that is when the layers of this crepe paper appear to look like a bees hive. |
Resurrecting this thread, since I've been finding this type of insulation in the older homes, primarily the attic. This is Kimsul Insulation that was manufactured by Kimberly Clark way back in the 1930s and 40s and was supposed to be the greatest thing at that time. It was also used for trailer insulation. It appears like layers of crapepaper or cardboard, but today you will find it flaking and disintegrated. Look on the paper, covering that looks like rosin paper, reddish and you may see "Kimsul". However, please be careful in the attics and wear protective gear (at least a particle dust mask) since this product contains asbestos. They no longer make this product, but they do still make lots of toilet tissue, paper towels and other paper products. It did come in a gray paper facing as well, which claimed to be reflective. The product did work well in it's day, but because of the asbestos component, it's a NO MORE made, but it is still out there in the older homes.
http://www.google.com/search?q=kimsu...w=1002&bih=504 |
Thanks Debra good info Much appreciated .
Roycooke@hotmail.com I prefer E-mail Roy Cooke UE mlarson is on my ignore list "All that is necessary for the triumph of evil is that good men do nothing"----- - -Edmund Burk |
Paul Bowman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Still wise to wear a dust mask in any attic and around insulation generally, of course. |
| Insulation type | wcorbett | Ancillary Inspection Services & Additional Topics | 5 | 7/22/07 9:44 PM |
| Vaulted Ceiling Insulation | rcooke | Canadian Inspectors | 4 | 1/22/07 12:24 PM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 5:25 PM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
