Old 5/18/11, 4:50 PM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
Question Interesting wood shavings and sawdust insulation
Found this wood fibre insulation matt as the ONLY stuff up there. I wonder what it was called -i wonder if mold like substances would flourish in it, I wonder if its flammable, should i recommend it get removed?
There definitely a need for more insulation up there.
interesting-wood-shavings-and-sawdust-insulation-1043-n-kenilworth-parkway-oak-park-il-60302-263.jpg
Joseph Tribuzio 708 453 8447
Tribuzio Home Inspection Services
CHICAGOLAND, ILLINOIS
www.thishomeinspector.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/18/11, 9:25 PM
Banned
Default Re: Interesting wood shavings and sawdust insulation
Only if it got wet.....but then the untreated wood framing next to it will rot also if it gets wet .
All the wood framing and sheathing in most houses is flammable also!!
Old 5/19/11, 9:36 PM
uh, yeah Brian, i have kind of a dry sense of humor sometimes, ya know?
I really was hoping to get a trade name for this material , i recall some one commenting on something similar to this.
any one?
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 5/20/11, 8:56 AM
Barry Adair's Avatar
looks like a magnified version of Masonite siding back side, any I.D.
possibly a celotex, beaver board, buffalo board and a number of other names type product usually about 1/2" or thicker panels with some brands asphalted on the surface an attempt to resist moisture
many moons ago we used as underlayment for brick, stucco and concrete control/expansion joints
wiki says
Wood fiber insulation is available as loose fill, flexible batts and rigid panels for all thermal and sound insulation uses. It can be used as internal insulation : between studs, joists or ceiling rafters, under timber floors to reduce sound transmittance, against masonry walls or externally : using a rain screen cladding or roofing, or directly plastered/rendered, over timber rafters or studs or masonry structures as external insulation to reduce thermal bridges. There are two manufacturing processes:
* a wet process similar to pulp mills in which the fibers are softened and under heat and pressure the ligin in the fibres is used to create boards. The boards are limited to approximately 25 mm thickness; thicker boards are made by gluing (with modified starch or PVA wood glue). Additives such as latex or bitumen are added to increase water resistance.
* a dry process where a synthetic binder such as pet (polyester melted bond), polyolefin or polyurethane is added and the boards/batts pressed to different densities to make flexible batts or rigid boards.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 5/26/11, 6:11 PM
wiki says
RIGHT ON,,, Thank you Barry ..yes the stuff appeared to have been formed with a wet - pressed process - i didn't note any binding substance.
It was flexible and i'd describe it as being in blankets of sorts.
It was also found against foundation wall.
In any case, it was insufficient. just one inch of the stuff.
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
