Old 7/19/07, 12:03 AM
Joe Funderburk, CMI's Avatar
Default Interior Stair Illumination
Interior stairs had a switch at the bottom of the flight that controlled a high ceiling fan light in the vaulted ceiling of the adjacent great room. The switch at the top of the stairs controlled the upstairs hall light.
I usually see both switches controlling the same light. Do you see this as a problem?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 7/19/07, 12:12 AM
Bob Elliott's Avatar
Default Re: Interior Stair Illumination
Yes... it more than likely needs a three way switch for the light at the top of the stairs.
Old 7/19/07, 12:14 AM
Not sure if I was clear...the switches at the top and the bottom control separate lights.
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/19/07, 12:28 AM
Christopher Currins's Avatar
That is what Robert is saying, there should be a switch at the bottom and one at the top of stairway that control the One light in stairway, a three way switch. It sounds like the ceiling fan may have been installed later and they replaced the switches and used the available circuit to operate the ceiling fan.
Christopher Currins
Certified, Licensed
Old 7/19/07, 12:33 AM
I'm in agreement. The c-de doesn't clearly state that a the upper and lower switches must control the same light, however.
Theodore Roosevelt
Joe Funderburk, CMI
Old 7/19/07, 12:37 AM
Jeffrey R. Pope's Avatar
The stairway lighting, which must be capable of lighting the entire stairway, including all landings (top ,bottom and center), must be operable from the top and bottom landings. The switches must be located and accessible without descending or ascending any step.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/19/07, 7:49 PM
David C. Macy's Avatar
There are numerous older homes with basements in this area that only have a switch at the top & no 3 way operation.
Do you know when this was made a code?
Lets say a 1966 ranch with a basement has no 3 way basement lighting.
The picture is from a 8 year old colonial that had the basement 3 way mounted in the sub floor drop ceiling. The only reason I was able to locate is the owner & his son were home and overheard me talking about having 3 way lighting and then said it was in the subfloor.
Old 7/19/07, 10:48 PM
It's been in the building codes for many years, but if it's not a "finished" basement, the rule generally won't apply. Just as it wouldn't apply to an attic with stairs or a pull down ladder.
Regardless, all permanent stairways between "habitable" floors (top to basement) should be equipped with appropriate lighting as described in my previous post.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/21/07, 10:36 PM
lfoster's Avatar
lfoster lfoster is offline
When stairs have 6 or more risers, a 3-way switch is needed at top and bottom. IRC 3803.3
I would read this that the switches needed to control the lights for the stair illumination, not the adjacent room.
Emergency Lighting (commercial) mcyr Electrical Inspections 24 6/10/06 10:06 AM
