Old 11/12/08, 8:23 PM
Harry V. McBride, III's Avatar
Harry V. McBride, III Harry V. McBride, III is offline
Default Kitchen Exhaust Hood
Kitchen exhaust fan and light does not have a liner in the area around it. Exposed wood and drywall. Should a metal or steel liner have been built in this area to keep it from being covered with grease when cooking?
Old 11/13/08, 12:02 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Kitchen Exhaust Hood
I do not have a good look in the picture , though I could add contrast , but I am guessing that the cabinet forms a scoop around the range hood.
Will it get more greasy?
yes.
Because more grease is being channeled into that area.
I do not know how close to the stove it all is.
May not be an actual defect , but may be worth mentioning in the report.
Realize that cabinets are built over stoves all the time.
Old 11/13/08, 1:02 AM
Dale Duffy's Avatar
I would state if it was mine, I would want it lined with stainless steel, simple as that, because it would make sense.
Old 11/13/08, 1:05 AM
Dale Duffy's Avatar
I do not know what the manufacturers specifications are for installation, but it would only make sense to have it lined with something easy to clean which grease would not embed in.
If it was a commercial application it would be all stainless lined.
Old 11/13/08, 9:23 AM
gbeaumont's Avatar
Hi to all,
that appears to be a very poorly built "custom range canopy" frankly I have never seen it done quite like that, looks like they used whatever was on hand.
IMO the canopy should have been built with laminated ply which offers some protection from steam moisture and is easily wiped clean, also I have never seen a blower mounted on the surface like that, they are normally flush fitted into the lower panel.
We had a custom kitchen company for years and we wouldn't have built one that shoddy.
It should look something like this from below:
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 11/13/08, 9:57 AM
David A. Andersen's Avatar
Dale,
Are you using common sense?
I thought everything we did had to be a building code requirement!
Agreed!
BPI# 5015804
Old 11/13/08, 4:17 PM
Thanks everybody! Dale I appreciate it that is what i thought. Thanks again!
Old 11/13/08, 4:18 PM
You too Gerry!
Seminar on the Design,Construction and Installation of Commercial Kitchen Exhaust Sys mkyriacou Canadian Inspectors 5 7/21/08 9:22 PM
Complex challenge with bath exhaust fan - need help with solution! Bill Featherstone Electrical Inspections 11 11/5/07 2:16 PM
Kitchen Ventilation? whandley Inspecting HVAC Systems 15 7/13/06 9:28 AM
Range exhaust hood question mmorgan Interior Inspections 24 4/20/06 10:50 PM
