Old 3/11/07, 2:36 PM
rmorella rmorella is offline
Send a message via AIM to rmorella
Default Kitchen floor evaluation
I did an inspection for a seller yesterday and in the kitchen there is a slight dip in a section of the floor near a door opening. The floor is ceramic tile. I went into the basement and put my level on all the associated floor joist in this area and they are all level. No indication of any cracks or defects in any of the joists.
After talking with the homeowner (they installed the floor) they mentioned that they may have went thinner on the thinset in this area. It is my opinion that this is most likely what happened...uneven thinset under the tile in this area. They were probably trying to hurry to get the job finished, since they were near the end.
You really can't feel the dip unless you knew it was there and felt for it. It is visually noticable as you walk into the kitchen from the family room. Although, the door trim on the left side was cut too short (it is about an inch+ above the floor). I am thinking that this gap drawers your attention to the floor area where you can then see the dip. I would bet that if the trim went to the floor it would probably be a lot less noticable.
Anyway, the question is, would you refer this for a structural engineer to evaluate?
Thanks for any help.
Ralph
Ralph Morella
R J Morella Inspection Services, LLC
Marietta, GA
NACHI07011501
Old 3/11/07, 3:05 PM
Joseph Hagarty,  CMI's Avatar
Default Re: Kitchen floor evaluation
The homeowner suggested that the installation of the flooring may have been deficient.
If no apparant deficiencies are visibly present on the framing and/or subflooring below, further review by a flooring / tile contractor would be reasonable for an initial evaluation.
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 3/11/07, 4:51 PM
Ditto;
It is very easy to create a cupped look in a ceramic tile floor when using a 3/8" notch trowel to spread the thin set material and set the tiles. Especially when done by a homeowner.
Marcel
</IMG></IMG>
Old 3/11/07, 11:35 PM
Thanks for the responses. That is what I kind of figured.
Ralph
Ralph Morella
Marietta, GA
NACHI07011501
Old 3/12/07, 7:57 AM
David P. Valley's Avatar
A sloped floor is not an indication of structural issues. I've ran into many sloped, cupped and unlevel floors and more than half of them are simply from settlement of the house over the years.
Know your structure and what to look for in this situation, before you make the wrong call.
Old 3/12/07, 9:29 AM
Very good advice.
Abraham Lincoln
Old 3/12/07, 10:09 AM
Settlement of a Structure may be a Structural concern.
There are many causes for sloped flooring which are indicative of serious structural issues.
Phone: 610-399-3675
Old 3/12/07, 10:10 AM
And there are many more that are not. That's why I simply stated...
Old 3/12/07, 2:36 PM
Thanks for even more good advice.
Ralph
Ralph Morella
Marietta, GA
NACHI07011501
Kitchen on two circuits? rwashington Electrical Inspections 2 8/18/07 5:19 PM
Kitchen floor slopes?? crichiii Structural Inspections 6 5/29/07 8:24 PM
Electrical Panel in Kitchen Cabinet maitai11 Electrical Inspections 9 2/27/07 7:34 PM
No GFCI in Kitchen rnewland Electrical Inspections 6 9/19/06 8:51 AM
Kitchen Ventilation? whandley Inspecting HVAC Systems 15 7/13/06 9:28 AM
