Old 2/13/09, 8:13 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Kitty Door
Is this pet door fire rated? It is installed in a self closing fire door, between house and garage, so it must be.
Old 2/13/09, 8:37 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Default Re: Kitty Door
I write those up as a breach of the fire door. Never get questioned on it.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/13/09, 9:00 PM
Unmoderated Guest
How do you know the BIG door is fire-resistance rated? If it isn't, then the kitty door doesn't need to be rated.
Old 2/13/09, 9:01 PM
Unmoderated Guest
PS: If it's rated, there will be a UL label on the edge of the door.
Old 2/13/09, 9:49 PM
iniquette's Avatar
I was assuming he already had verified fire rating for the big door.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/13/09, 9:54 PM
Come on guys, I'm sure no one would ever install anything but a fire rated door where they are required, let alone install anything but a fire rated kitty door cut into such a fire rated door...got it?
Larry Kage, CMI
231 929 3525
Old 2/13/09, 10:25 PM
Why bother with negating a fire door, just train the cat for krist sake.
A cat opens the door - Video
Marcel
Old 2/13/09, 10:28 PM
The big door was fire rated and self closing.
Old 2/13/09, 10:48 PM
iniquette's Avatar
Marcel
I retract all previous comments and now go with Marcel's advice.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/13/09, 11:13 PM
Wayne B. Wilson's Avatar
The entry into the house from the garage must have a 20-minute-rated fire door—a minimum 1 3/8-inch thick solid wood or steel door. The UBC additionally requires the door to be self-closing and self-latching.
Old 2/13/09, 11:28 PM
As it is required by most jurisdictions that have adopted the IRC and IBC Wayne.
http://www.aureliustwp.org/Portals/3...RAGE%20SEC.pdf
Marcel
Old 2/13/09, 11:35 PM
iniquette's Avatar
And that cat door is a breach in the door. Correct?
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/13/09, 11:44 PM
Unless it is one of these, which it is rarely encountered.
Pet Ready Exterior Replacement Doors XPD75 Series
Now you can replace your existing door with this Pet-Ready Exterior Door. It is a fire rated and insulated pet door that is engineered and sized to fit industry standard 32" x 80" or 36" x 80" home door case openings.
Specifications:
  • 1 3/4" thick insulated flat steel exterior replacement door
  • 32" x 80" Door measures 31 3/4" x 79 3/4"
  • 36" x 80" Door measures 35 3/4" x 79 3/4"
  • Three Quarter 22" x 48" double pane insulated glass window
Features:
  • Doors include a bottom door sweep
  • Doors are primer-coated white
  • The doors are not bored for the door handles or countersunk for door hinges. These should be done at the customer’s home using the existing lock/hinges and door as a template, ensuring the door handles and hinges will be placed correctly when installed.
  • Pet door (flap) available in several size options to accommodate your dog
  • Fire rated and insulated door
  • "Custom Made Easy" design - Your choice of window style and pet door:
    • Clear 1-Lite (Full Glass) Design
Marcel
Old 2/13/09, 11:54 PM
Marcel,
Thanks!! Good information. The door in question is not the type in your information.
Old 2/13/09, 11:55 PM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Marcel,
I don't think that door would be approved for use into the garage. It states it is an exterior door and while the door itself may be fire rated, I don't know of any movable flap that would meet the fire rating necessary.
Overall, I would say the cat would be good stir fried with teriyaki sauce and rice.
Stephen Stanczyk
www.FireDoorInspector.org gromicko Commercial Inspections 108 1/12/09 3:39 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 11:48 AM
Bad Door and Water on the Floor jnicholson Exterior Inspections 7 10/4/06 10:45 PM
