These images are from a condo inspection today. The loser level is the garage, the unit inspected is above the garage, then another unit above. The images are all on the south wall. The interior walls are from the 2 adjacent bedrooms. the CMU are in the storage rooms in the garage on the south wall. I think there is a structural issue, and think they should have a SE take a look, but wanted to see what some of you guys think.
Michael Merino Merino's Home Inspection & Education Inc. "Not just an Inspection, an Education"SM Phone/Fax 708~535~6057
| Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
May not be structural.
Continuation of images
The exterior had this, with no issues found on the brick
Ok now it looks structural.
Is that the garage below in the second set of pics and tell more of the structure. How old ? Brick veneer or just CMU ? How do the downspouts terminate.? Is their cracking in the slab? Looks like building may not be to old,(age please.)(appears in the picture they patched some cracking in the CMU previously. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 1/17/10 at 8:48 PM.. |
Hmmm Something is moving there
I think you are both correct, but I was perplexed that none of the exterior brick is disturbed, no cracks, no repairs. Also, in the attic, I can see daylight from the south wall. I took a pic with no flash, here it is.
I don't think duct tape will fix this one
dam, I will remove that recommendation from the report. LOL
No weeps and definite foundation issues.
Recommend structural engineer. |
Bob, why would the brick not have any damage? I thought for sure I would see some issues.
One explanation may be because the brick is moving independent, since it is really just siding that sits on the foundation. The former could explain where the moisture barrier went ,that should be seen at the brick/concrete intersection. Just a guess though. (on second look the mortar should show issues, so this is not new,is it) ? |
Sounds reasonable. I didn't see any tuck pointing. But, I agree that the veneer may be moving independently. Thanks for the help Condo Bob!! Will you be at the next NACHI meeting? I will be there.
would the mortor do that if it is not strong enough?
Am I right ? |
| Foundation wall cracks and bowing | jmanders | Structural Inspections | 8 | 5/27/09 9:03 PM |
| Watch the new episode and learn how to identify different structural cracks. | gromicko | Structural Inspections | 2 | 4/25/09 12:02 AM |
| Structural foundation issue | tlorenz | Structural Inspections | 8 | 4/19/09 7:22 PM |
| Basement vapor barrier | jfrederick | Interior Inspections | 10 | 2/14/09 4:54 PM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 4:52 AM |
