Old 1/7/08, 9:33 PM
sfalvey sfalvey is offline
Default Laundry chute
What do you guys think about laundry chutes in a 2002 home?
Thanks,
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 1/7/08, 9:37 PM
Brian E. Kelly's Avatar
Default Re: Laundry chute
Mighty handy.
I usually point them out as a safety concern though.
Old 1/7/08, 9:52 PM
phinsperger's Avatar
I think its better to design the laundry to be on the second floor or what ever floor the bedrooms are on. With a laundry shute you still have to lug the clothes back up.
Addtionally the shute itself acts like a chimney in the even of a fire which is common in laundry rooms ( about 25,000 dryer fires per year). There should at least be a spring loaded fire stop separating the shute at each floor level.
And of course Brian pointed out that they can be a safety hazard for children.
Old 1/8/08, 10:05 AM
Unmoderated Guest
Someone once took a survey about where people wanted the laundry located...in the basement, in case there's a flood; on the first floor where the housewife spends moast of her time, or on the second floor, where all the laundry is generated. The results: One-third for each preference.
What's a poor architect to do?
Old 1/8/08, 11:57 PM
jkogel jkogel is offline
I think it's poor practice to put a laundry room upstairs - the washing machine inevitably will spring a leak or overflow while no one is watching it. Better to keep it downstairs, near a floor drain.
There are two dangers associated with laundry chutes - flames or fumes coming up from the basement, or little kids falling down them, although generally kids are smarter than that.
Old 1/9/08, 9:10 AM
I guess we shouldn't put bathrooms (which in my experince have water overflow problems more than washers) on the second level then either.
Old 1/9/08, 9:20 AM
sspradling sspradling is offline
Please Note: sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Great way to get the cat into the basement.
Stu
Old 1/9/08, 9:55 PM
The upstairs bath is kind of a necessary evil, until they design a people-friendly laundry chute.
Old 1/12/08, 10:40 PM
jbettencourt jbettencourt is offline
Please Note: jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
You are required to have a floor drain in an upstairs laundryroom in this area as far as I am aware.
GFCI - Laundry charper Electrical Inspections 8 8/27/07 2:31 AM
Ill inspector 2nd floor laundry floor drain? ebethel Plumbing Inspections 1 7/18/07 10:59 PM
drain for laundry brepanshek Plumbing Inspections 1 6/3/07 8:51 PM
Minimum height for laundry standpipe? bmargiotti Plumbing Inspections 7 2/27/07 9:35 PM
Laundry chute? mmasney Interior Inspections 9 2/15/07 7:32 PM
