Do you guys write up a leaky shower head?
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Why would you not?
Recommend repair or replacement. |
Is it leaking because of the valves, or does it just need to be tightened at the goose-neck?
It appears to be valves it looked fully tightend
In Illinois the only option is to recommend a State Licensed Plumber,however it sounds like it needs a new washer,which is usually on the hot side as they deteriorate faster.
Thaks for the help bob
If anything is leaking it gets wrote up imo
Yes, always.
Alabama Home Inspections www.thebirminghamhomeinspector.com Home Inspections in Birmingham, Montgomery, Huntsville, and Tuscaloosa. |
I put it in the body of the report as it is not going to adversely affect the home; if I know the fix then I put that as well at the same time I also advise them which tradesmen to contact.
Jeff, with all due respect, that is incorrect, the NC SOP states that the summary should include any item not functioing as intended OR adversely affects the habitability of the home. If it had "AND" instead of "OR" you would be correct. From the NC SOP: (note this is from 10-09 SOP and will change somewhat when the new law gets incorporated into the SOP but it will not change whether or not this writeup belongs in the summary at all) (d) Written reports required by this rule for pre-purchase home inspections of three or more systems shall include a separate section labeled “Summary” that includes any system or component that: (1) does not function as intended or adversely affects the habitability of the dwelling; B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Hi Bruce,
I am aware of that at the same time I look at the spirit of the law....not the letter. If we were to write up every little thing and place it in the SP under that narrow scope then we would all be writing a long time........ if a shower head has a couple drips of which I could tighten same and resolve it (if its the valve then a different story) then I deem that while it is note worthy not in the SP; interior doors that slightly bind from seasonal wx changes (no cracks in plaster or drywall at top corners) that can be adjusted by a 3 inch wood screw.....body of report; vinyl siding panel that has moved through thermal expansion and contraction.....body of report on how to fix same; cabinet door misaligned yet has adjustable hinges....body of report. Under the NC code of ethics one of the most important statements that I hold true states: "Opinions expressed by licensees should only be based on their education, experience and honest convictions." With that said, based upon my education, experience and honest convictions there are going to be items for which I deem minor yet noteworthy...... other inspectors may not deem them in the same manner because of their education, experience and convictions. warm regards Jeff |
Yes, and I will write up an occluded shower head as well.
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yes.
Per IL SOP we have to write up anything that is unsafe or not functioning. |
yep...why would you not?
The shower head is not leaking, it's the control valve. Remember , there is no such thing as a hot water heater! You can have a water heater or a water tank, but not a HOT WATER HEATER>
| Dallas Inspector finds shower leaks using Infrared Thermal Imaging | kweiss | Thermal Imaging, Infrared Cameras & Energy Audits | 10 | 3/9/09 8:59 AM |
| No caulking at shower wall to pan seam? | hmiller | Interior Inspections | 11 | 2/9/09 7:40 PM |
| Bath - No Shower! | rmaday | Plumbing Inspections | 11 | 6/2/08 8:43 PM |
| Low water usage shower head - squirts | lfoster | Plumbing Inspections | 4 | 6/2/07 12:40 PM |
