I recently inspected a home and the light switches were installed upside down, home handy man. I verbally mentioned this to the new buyer, should I include this in my report?
Bruce |
What did the rest of the electrical system look like?
If that were the only electrical issue I found I wouldn't bother, and just tell the buyer verbally. However it is a clue that there have been "handy man" repairs, and if that was just one of several indication of unprofessional work, I might reccomend a thorough electrical evaluation. PS. It's beyond the SOP, but it might also be worthwhile pulling the cover off of one of them and making sure that they are wired correctly. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Always CYA! |
Wouldn't it be a safety issue? Almost like reversing the hot and cold lines on a shower. I am not sure I understand how pulling off an outlet/switch cover would require a call to my lawyer? Would it be that if I only pull one and not everyone in the house that I have opened my self up to liability for suspecting something and not verifying it through out the house? I am not objecting to what you say but just trying to learn.
Thanks, Dick Dick Moran True Blue Home Inspections A Div of RAM2, LLC. Clarksville, MD 240-832-6838 MD Home Inspector License 29927 |
If it is a toggle switch, the UP position will be the correct position for proper operation of the outlet it supplies.It is a Defect.
Joe,
Not being a smart a.., nor am I arguing, but am honestly inquiring... What is the harm if on is down, and up is off? To me it's like saying the top of a map is always north. (Usually, but who says it has to be that way.) Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
An Indicating general-use and motor-circuit switches, circuit breakers, and molded case switches, where mounted in an enclosures, must clearly indicate whether they are in the open (off) or closed (on) position. I hope you will add this as a defect in future reports, as simple as it may sound it will cover your *** if someone trips and breaks a leg or arm in the future. |
You walk into a room and reach for a switch in the dark, you're going to flip it. You don't even think about if it's in the right position or not. So is there really any harm in all of them being reversed? Other than it's unusual, and implies Harry Homeowner has been at work, I don't see the harm. Once again, I'm not trying to argue, just trying to understand where the problem lies. Thanks in advance. I really do appreciate your input. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
I agree with you. Just because it is customary does not make it wrong. Joe, How would this type of switch fit into your aforementioned statement? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
I am sure that you are not pleased hearing that what you see as no problem is really a problem in the eyes of many in the inspection community, and for those who have been including this issue as a defect.
Three and four way switches are installed and operate up or down, and with no problem seem to be acceptable. If I was called to make a final inspection, and I have for thousands of dwelling units, I would leave a red tag when I found the single pole switch up side down! Too bad we have to waste our valuable time arguing about this issue, again I am right and you are wrong and must begin to remember the subject of safety, and that's what its all about. The push button switch is simple "pusha da butone Guido" |
Everyone here is safety oriented. Don't call this discussion something it's not. If I am to declare this issue as a defect in my report, I want to be 100% certain it is based on fact. Not the opinion of someone who consistantly advises HI's to go way beyond the scope of an inspection. Is there code that substantiates your statement? No, I don't inspect to code, but as we all know, code (and safety) is the basis for our findings. BTW... "flippa da switch, Vern" !!! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Practical Safeguarding. The purpose of the NEC is the practical safeguarding of persons and property from hazards arising from the use of electricity. Here's a member that was not happy with the answers he received elsewhere and decided to ask the electricians! http://forums.mikeholt.com/showthread.php?t=94243 |
Hahaha
Let me throw this into the mix. When you look at a breaker panel does the breaker flip on to the left or the right............hmmmm |
| CFL Bulb Breaks: Leave For 15 min. | jmckenna1 | Miscellaneous Discussion for Inspectors | 44 | 7/19/08 6:34 PM |
| Trouble Shooting the Simple Light Bulb | mcyr | Electrical Inspections | 20 | 1/6/08 4:47 AM |
| End of the light bulb as we know it!! | mcyr | General Inspection Discussion | 3 | 12/19/07 4:42 PM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 8:22 PM |
| How many forum members to change a light bulb? | kshepard | Miscellaneous Discussion for Inspectors | 9 | 8/2/06 10:56 AM |
