Old 1/20/06, 2:26 AM
Joe Funderburk, CMI's Avatar
Default Manufactured fireplace issues
Today I inspected a sealed, vented manufactured fireplace. The glass was stained badly on the inside. What's the reason? Is is fixable or does it need to be replaced? (Can the glass be easily removed?)
Also, the interior walls of the metal firebox had lots of corrosion. I'm guessing due to condensation. How unusual is this?
How would you advise?
(Sorry I can't post a photo...BBS says I'm logged in but when I try to upload a photo, it say's I'm not. Another issue altogether.)
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 1/20/06, 8:28 AM
Mark R. Long's Avatar
Mark R. Long Mark R. Long is offline
Default Re: Manufactured fireplace issues
In most cases the glass can be easily removed and cleaned. Usually, there are clasps on the bottom to release it. The cause of the stained glass is most likely due to the air adjustment not being set properly, so the combustion is not clean, it is sooting . Not uncommon. On some models it is an easy adjusment and the home owner can do it. Other models its not so easy.
The corrosion inside has me a little confused. Do you think that it is actually corrosion? It may just be a residue buildup from the un-clean burn. If it is actually corrosion, the fireplace may be very old and/or it's been neglected and/or there is a venting issue.
At any rate, my advice would be; "Recommend further evaluation by a qualified/certified fireplace professional and repair/adjust as necessary."
Mark
MD HI Lic # 30090
BPI Certified Building Analyst
PA DEP Radon Cert # 2457
Certified Home Energy Tune-uP Inspector
Old 1/20/06, 11:19 AM
Thanks for the info. About the corrosion, there is definitely lots of rust on the walls of the firebox. House is 8 years old. I did refer it to a specialist.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/21/06, 1:08 PM
Russel Ray's Avatar
White film on glass panels. According to Mr. Dale W. Feb, Executive Director of the Fireplace Investigation, Research, and Education Service (Moorpark, California), the white film is sulfuric acid. All fossil fuel produces sulfur during the combustion process, and when this sulfur is mixed with moisture, sulfuric acid is created. The white film (acid) may permanently etch the glass and should be removed on a regular basis. Permanent damage might already have occurred to the glass panels and replacement may be necessary. Recommend further evaluation by licensed fireplace professional. Information obtained from http://inspectionnews.com/ubb/Forum7/HTML/000129.html.
Sometimes the link doesn't work, but it does seem to be working as of 0908 this morning, and there is a good picture in the first post of the thread.
Dale's post is the eighth one down, but certainly read the whole thread. Very informative.
Old 1/21/06, 1:24 PM
Thanks Russel. Very helpful.
Theodore Roosevelt
Joe Funderburk, CMI
The Rumford Fireplace: Safety vs. Efficiency mbryan Interior Inspections 2 4/28/08 5:38 PM
AFCI in manufactured housing sfalvey Electrical Inspections 2 6/13/07 12:25 AM
Inspection of and Issues with Manufactured Housing pmaietta General Inspection Discussion 0 2/3/07 8:20 AM
Inspection of and Issues With Manufactured Housing tvalosin Inspection Education & Training 0 2/2/07 8:54 PM
