Old 12/24/10, 12:57 PM
Philippe G. Heller's Avatar
Philippe G. Heller Philippe G. Heller is offline
Default Is this material likely to contain asbestos?
The panels measure about 2' x 4' and were installed in the early 1970's under carpet. The material is similar in color to a transite pipe. Is anyone familiar with this material? And is it likely to contain asbestos?
material-likely-contain-asbestos-dsc06262.jpg   material-likely-contain-asbestos-dsc06261.jpg
Philippe Heller
The San Diego Real Estate Inspection Co.
http://www.sdinspections.com
www.facebook.com/sdinspections
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/28/10, 4:42 PM
Vince Santos's Avatar
Vince Santos Vince Santos is offline
Default Re: Is this material likely to contain asbestos?
It could but who knows unless you have packaging laying around with these tiles in it. Or you would need to have it tested. Was it damaged or in good condition?
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
Old 12/28/10, 5:10 PM
ldapkus ldapkus is offline
Yup.
Bob Elliott's Avatar
Soak it down first if removing but looks suspect and caution might be to test.
I assume someone just removed a linoleum sheeting from on top.
Old 12/28/10, 5:43 PM
Most likely and best if tested for confirmation.
I used that product in that circa.
Transite originated as trade name that The Johns-Manville Corporation created for a line of asbestos-cement products, including boards and pipes. In time it became something of a generic term for other companies' similar asbestos-cement products, and later an even more generic term for a hard, fireproof composite material, fiber cement boards, typically using in wall construction.
The use of asbestos to manufacture transite was phased out in the 1980s. Previously transite was made of cement, with varying amounts (12-50%) of asbestos fiber to provide tensile strength (similar to the steel in reinforced concrete), and other materials. It was frequently used for such purposes as furnace flues, shingles, siding, and wallboard for areas where fire retardancy is particularly important. It was also used in walk-in coolers made in large supermarkets in the 1960s, 1970s and even the 1980s. Other uses included roof drain piping, water piping, sanitary sewer drain piping, and HVAC ducts. Because cutting, breaking, and machining asbestos-containing transite releases carcinogenic asbestos fibers into the air, its use has fallen out of favor.
Old 12/28/10, 5:48 PM
This was in a house built in the 1960's and the product was installed at the upstairs room addition beneath the carpet. I recommended testing to be safe.
Philippe Heller
Old 12/28/10, 6:00 PM
Good call, I would have done the same, even knowing it is .
Asbestos.............What is asbestos? mkyriacou Ancillary Inspection Services & Additional Topics 2 9/17/09 5:03 PM
Asbestos jmckenna1 Miscellaneous Discussion for Inspectors 0 1/26/07 11:11 PM
Asbestos jmckenna1 Miscellaneous Discussion for Inspectors 0 1/26/07 11:09 PM
Is this a competent asbestos removal job? Is our basement now a biohazard? David Paterson Ancillary Inspection Services & Additional Topics 5 1/16/07 7:16 PM
