Old 10/25/07, 3:08 AM
Default Methods for finding uninsulated wall cavities
An insulation contractor told me he goes into a bedroom closet, pokes a little tiny hole in the exterior wall at the bottom corner just inside the door, then sticks a little bent wire in there and rotates it like a pinwheel. That's how he finds missing insulation.
I've been removing cover plates and that usually works, but sometimes you have to cut the drywall back a little and it's messy. I'll bet a little wire with the end bent onto a hook would work better at outlets.
I wonder if someone were to hold an electronic guitar tuner next to the wall while tapping the wall, if empty cavities would sound a different note from full cavities. Hey! An excuse to have another electronic gizmo!
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 10/25/07, 7:43 AM
Barry Adair's Avatar
Default Re: Methods for finding uninsulated wall cavities
IR thermometer worked before I had a camera.
Now I just use the camera.
You can scan a house just about as fast as you can move if you are only looking for insulation absence, voids or air leakage.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/26/07, 2:33 AM
With the IR thermometer, during real hot or cold weather I guess it would be obvious. What about when it's 70 degrees out and indoor and oudoor temperatures might be naturally similar?
(303) 717-8940
Old 10/26/07, 2:49 AM
Roy D. Cooke, Sr's Avatar
I also test Radiant ceiling elements and base board heaters.the same way works well .
Before I had to use a spray water bottle it dried where element was .
Yes they have to be turned on..
.... Cookie
Old 10/26/07, 5:15 PM
William J. Decker's Avatar
I did an inspection for a guy, yesterday. Condo conversion. I had previously done a pre-drywall inspection for him on the property. I told him, and the builder, to make sure to not only install insulation, but also vapor barrier on the outside walls (the unit is a garden apt).
During yesterday's inspection, I could not see any insulation, at all. (used the B-Cam and checked, with a boroscope, through the receptacle boxes. The contractor kept swearing that he insulated. I told him, "Prove it. Cut out a section of drywall, right here."
He got all upset, claimed I was calling him a liar and stormed out.
Needless to say, today's closing was cancelled .
Client loves me.
The B-Cam helps and makes thinsg a little easier and faster, but it cannot be a complete substitute for visual inspection.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 10/26/07, 6:10 PM
bzimbelman bzimbelman is offline
Client loves me.
Hope this helps;
Will -
Great to hear you were able to determine that, just one question from the uneducated (b-cam wise):
I was told you need about 30 degree inside/outside temp differential to 'see' insulation with a b-cam, is that correct? Does it vary based on the type of insulation, thickness, etc?
What would your results be at 10 degree difference, or 20, or 5?
The reason I ask is many (most) of my inspections are done when the temp differential is far less then 30 degrees. Of course I could test the heater in the summer for say, two hours and maybe get the house to 110 so I could do an insulation scan
Old 10/26/07, 6:55 PM
I've detected absent or loose insulation at TD lower than that.
All IR anomaly readings (thermometer or camera) rely on thermal loading of some sort. If everything is the same temp no conclusive results can be ascertained.
Remember we are always looking for differences, inconsistencies or unusual conditions.
Again IR is just another tool, not the do-all, end-all. We'll have to find other methods when temps are the same throughout.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 10/26/07, 7:24 PM
Peter C. Russell's Avatar
Here's one I did, new home selling for 399K
Old 10/26/07, 7:40 PM
What do those pictures show Peter?
Larry Kage, CMI
231 929 3525
Old 10/26/07, 9:20 PM
This house had the attic finished into a family room, the first picture shows one complete bay missing insulation from the ridge down to the knee wall, you can see the rafters running vertically and the strapping horizontally.
The second picture shows the A dormer ceiling in the same room and because the roof/ceiling is in such a small or tight area the insulation is just jammed in, should be ( "fluffy not stuffy" )
By the way, my client, after hiring me to add infrared to the inspection did not feel this was a big deal and did not pursue it with the builder and on top of that, the attic/family room has electric heat. OH well!!!!
Old 10/26/07, 9:41 PM
Cool. So there was a 4.5 and 6.5 degree difference in the two photos. The room temp appears to be about 80, what was the outside temp? Weather conditions?
Old 10/26/07, 10:17 PM
Outside temp. was about 90 in the sun, not sure what the temp. on the roof surface was.
Old 10/26/07, 10:20 PM
Attic was undoubtedly warmer. Thanks Peter!
Old 10/26/07, 10:46 PM
Yes, thanks Peter.
Larry Kage, CMI
231 929 3525
Old 10/27/07, 9:00 AM
We could always go back in time
we'll see what I can drum up during today's insulation "energy" inspection.
ADAIR INSPECTION
972-487-5634
TREC # 4563
VIDEO--Bowed Basement Wall, Cracks etc john bubber Structural Inspections 75 7/21/08 6:25 PM
Fire wall tyeager Structural Inspections 38 8/24/07 12:17 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 11:48 AM
damp proofing foundation wall interiors kshepard Exterior Inspections 13 2/28/07 10:04 PM
No Brick Ties - Wall Buldge Stew Structural Inspections 1 4/22/06 7:56 AM
