Is there any constuction or safety standard that a Home Inspector is looking for?
My picture could be better...The glass looked great and I saw no adhesion problem to the wall...it did have a metal boarder that was inserted on the bottom. ![]()
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Glass-panel "accessories" are not addressed by model codes. This is one of those areas where you will need to rely on "common sense."
Again it's what the inspector can't see. I have a similar installation in my house. Often there are concealed fasteners behind the mirror and attached by screws to the wall studs.
Inspection Support Services Inc. "Those who can do. Those who CARE, teach" or “Teaching is the highest form of understanding.” Aristotle |
Thanks Jeff
thanks for the info.
Glass and Glazing rules. All mirrors should have some type of mechanical fastener(aka-"J" channel top and bottom, or "J" clips with screw). The reliance of "mirror mastic" alone is not recommended. Also mirror should be safety backed or tempered when used as door mirror or within 5' of hot tubs. Mirrors with mastic only can and will fall off the wall. Humidity plays a roll. Typical 1/4" thick mirror is razor sharp when it breaks.
| New post on RealMatcher: Questions to ask an Ohio Home Inspector | inxil | InterNACHI & RealMatcher Blogs | 0 | 2/11/11 8:50 PM |
| Goofy NHIE asks questions well outside of the SOP of a home inspection. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 211 | 8/1/09 10:04 PM |
| Honest questions about CMI | lcapaul | General Inspection Discussion | 496 | 2/27/08 11:38 PM |
| Some good questions that always need answers | jtedesco1 | Electrical Inspections | 5 | 6/16/06 9:10 PM |
