| Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera. |
I often see moisture in the bottom channel of vinyl windows. Would this be condesation formed due to temperature differences between the glass and the vinyl frame?
Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 |
rcooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
Tight blinds or curtins add to this as not much air to raise the window temp. .If they lower the humidity more air movement curtins not to tight to the window and not to close to the floor. All will tend to help .Try and keep the humidity below 50% . . Roy -- |
I inspected a house for a Realtor, the other day (the realtor's house, no RE transaction, he was just having some problems and he has referred me, so I thought I would help him out).
Turned out that the painter painted shut the weep holes at the bottom of the channel. A little screwdriver action and it was all fixed. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
What I see is not runoff from condensation which formed on the glass or windows that have been painted over, but the majority of vinyl windows I look at here in Colorado- a relatively dry state with average humidity around 25%- have either pooled moisture in the channel or moisture stains in the channel clearly indicating that moisture has pooled there in the past. The windows appear to be adequately sealed around the exterior.
I'm thinking maybe one of the window manufacturers could clear this up. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 |
Skip Storm is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are these sliding windows. Imeet with a window rep a few days ago about water sitting in the bottom track of a sliding door. He said some water will get in on sliding doors and windows. He said this is normal, a small amount of water will evaporate. He also said the track needs to be kept clean so the water will not get dammed up and the weep holes should be checked for clogs
That last reply was my first reply. I am a member of NACHI. Can anyone tell me why my post says I am a non member
Thanks in advance for any help Skip Storm Premier Home Inspections Unlimited |
"Staining" I mentioned was a poor term. It was the way dust and dirt look after pooled water has evaporated rather than an actual stain. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 |
| IAC2 In new residential construction | mcyr | IAC2 Forum | 0 | 10/9/07 7:45 PM |
| Moisture in slabs | mcyr | Structural | 7 | 8/20/07 8:33 PM |
| bbbb | mcyr | Structural | 1 | 8/19/07 11:26 PM |
| Moisture control for slab on grade in protecting floor finishes | mcyr | General Inspection Discussion | 2 | 8/13/07 8:53 PM |
| moisture on new windows | mcameron | HVAC | 0 | 7/11/07 12:06 PM |
