Go Back   InterNACHI Message Board > Specific Inspection Topics > Interior
Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera.
Old 1/9/08, 4:04 PM
David C. Macy's Avatar
Default Moisture Intrusion
The home is 7 years old.
Is the moisture staining by the floor & poured wall from?
A) Potential block in footer drains?
B) From the small gap between the floor & wall?
C) Old moisture, no need to worry?
I used a meter and was about 18 to 20%.
How would you report this condition?
Thanks
ID:	17310   moisture-intrusion-111008-028-small-.jpg.jpg
Old 1/9/08, 11:43 PM
jkogel jkogel is offline
Default Re: Moisture Intrusion
I see effloressence on the concrete in pic#2. It looks to be recent, within a year or two, so I would report - Moisture appears to be weeping thru from outside, further evaluation is called for, then elaborate on possible sources.
Old 1/9/08, 11:54 PM
Scott Widick's Avatar
Scott Widick Scott Widick is offline
Send a message via MSN to swidick
I agree.
Old 1/16/08, 10:11 AM
Mark Sylvester's Avatar
Mark Sylvester Mark Sylvester is offline
Send a message via AIM to msylvester
Looks like a cold pour crack that seeps. Was the sump pump pit full of water or was it running allot.
Recommend evaluation. Thats all you can do without speculating too much.
Mark Sylvester
P.I. Home Inspection Services
www.pihomeinspection.com
mark@pihomeinspection.com
Old 1/16/08, 11:11 AM
There was no sump
IAC2 In new residential construction mcyr IAC2 Forum 0 10/9/07 7:45 PM
Moisture in slabs mcyr Structural 7 8/20/07 8:33 PM
bbbb mcyr Structural 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
