Tea Tree Oil.
According to the owner of a local water proofing company Mold Remediation is a scam in that all you need is simple Tee Tree Oil to kill all mold. Anyone ever hear of this method.? http://www.essortment.com/home/moldmildewpr_sbli.htm http://moldremoval.blogspot.com/2006...-tea-tree.html |
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I have been told by it can be use as a cleaning agent and it is also used in several cleaning products on the market now.
Bob
A 460 WEATHERBY MAGNUM should kill a charging grizzly bear but if you don't apply it quickly enough or at the right location the results could be less than expected. The same would be true for any fungicide even Tea Tree Oil. |
Tea Tree Essential Oil (Melaleuca alternifolia)
Rashes, insect bites, nail fungus, dermatitis, ringworm, thrush, head lice, sore throats, boils, congestion, arthritis, cold sores, fatigue, useful for a wide spectrum of infections. Anti-infectious, antibiotic, balsamic, antifungal, antiviral, anti-parasitic, anti-inflammatory, expectorant, stimulates immune system, analgesic and antiseptic. Hastens healing of wounds, diaper rash, acne, ringworm and insect bites. Protects skin during radiation treatment. Encourages regeneration of scar tissue and reduces swelling. Acts as an oil-controlling agent. High germicidal value. Has the property to penetrate pus and by mixing with it, the pus liquefies which causes it to slough off, leaving a healthy surface. Asthma, coughs, throat infections, stimulates blood circulation and lymphatic circulation. Scent: Sharp, spicy, warm with medicinal tones, top note. Source: Branches |
I am assuming you are well read on the subject when I ask you where should it be targeted ?
Are you saying your suffering customers (not clients) are still suffering because Tea Tree oil does not work or because they applied it wrong? Can we all agree that mold exists only because of overly Humid conditions? Assuming we get rid of the humid conditions will Tea Tree oil kill the spores? If so then is it not the cure? I know bleach does not penetrate or kill for some reason. Does Tea Tree oil? If it is not the cure ,what is ? Is there a site where I can get better instruction on remediation in detail? or is this something mystical? |
Moisture is the culprit. Get rid of that, make sure it doesn't come back, then you can eliminate the mold with many different methods available depending on the severity of the problem. Here is an upcoming seminar which can get you some learnin' with regards to initial steps dealing with moisture issues. Spend some of that money and learn something tight wad.
Yes. Get out of that basement and get some learnin son.
That is a good price for that course.
I am in the middle of writing a mold remediation protocol for a lady who has been sick in her home many years now. She finally went to the right doctor who determined it was mold causing her to be sick. I have an email from this lady stating she uses tree oil to clean her home. Sad but true.
Karl your last sentance contains the term acceptable levels.
What are concidered safe Levels? |
| Interesting article about mold by litigation. | gromicko | IAC2 Indoor Air Forum | 16 | 5/5/11 7:48 PM |
| Fighting Mold — The Homeowners' Guide from CMHC | mkyriacou | IAC2 Indoor Air Forum | 1 | 9/17/09 2:32 PM |
| GAO calls for collaboration on indoor mold guidance. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 32 | 11/11/08 8:47 AM |
| The new scoop on mold insurance | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 2 | 1/1/08 1:30 PM |
| CMI imposter? | jbraun | Certified Master Inspector (CMI) Discussion | 118 | 11/26/07 4:55 PM |
