Old 12/22/10, 2:43 PM
David C. Macy's Avatar
Default Need help Identifying insulation type
Having a brain fart on the proper description of the loose fill insulation.
What is the approximate R value?
I did note the reversed vapour barrier. Actually I believe there should be unfaced insulation when adding over existing insulation.
Perlite & vermiculite are typically grey/brown, this type is white.
Thanks!!
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/22/10, 3:12 PM
Bob Elliott's Avatar
Default Re: Need help Identifying insulation type
Looks like expanded polystyrene at R value of 4@inch and yes no moisture barrier if doubled up like you say or the moisture can get sandwiched.
Close up would have helped.
Old 12/22/10, 3:21 PM
Here is a close up of one where they covered the K&T, wait till you see the crawlspace pics I have. This report is taking forever!!
They insatlled over R13 batts with a vapour barrier sandwich.
Old 12/22/10, 3:25 PM
Brian E. Kelly's Avatar
Yes the Vapor barrier is wrong, and I is an increased fire hazard installed that way, if it is a paper backing.
Old 12/22/10, 3:32 PM
Michael Larson's Avatar
The knob and tube cannot be buried and Poly S is flammable.
What a mess.
Michael Larson
Hudson, WI
Old 12/22/10, 3:45 PM
What a mess.
This was good compared to the crawlspace!!
Old 12/22/10, 3:47 PM
I feel for ya.
Those reports take forever.
One more reason to charge a premium for older housing while being careful to explain to your customer why you must.
Michael Larson
Hudson, WI
Old 12/22/10, 4:12 PM
I feel you on the reports.
What's the matter you can't do it in the van with in 15 minutes and print it out on site.
You must be lazy.
Old 12/22/10, 4:14 PM
You must be lazy.
I have suspected for a long time the guys that live in parts of the country where slab on grade is predominate just don't get it. Bob.
It would be fun to hear from someone that moved from area to another and have them relate their experience.
Michael Larson
Hudson, WI
Old 12/22/10, 4:18 PM
Lots of guys do fast reports here but I doubt they have my testimonials to go with them.
OK shameless plug, but you get the idea.
There is so much you can miss if you do not go over your pictures and there is no argument that stands up against taking many shots to protect yourself.
Notice I asked for a closeup and he provided one.
Checklist guys with the proud 15 shots would have no recourse for help here and would have an inferior report.
Old 12/22/10, 4:21 PM
Bob I can't remember the last time I took less than 200 pics at an inspection.
It has save my butt several times.
Michael Larson
Hudson, WI
Old 12/22/10, 4:37 PM
Not to mention Joe Ferry has an excellent new article on his site in regards to this .http://homeinspectorlawyer.blogspot....os-during.html
Old 12/22/10, 4:47 PM
Dale Duffy's Avatar
Mike
I inspect homes in northern Arizona where Basements-Crawlspaces are common, there are many old buildings built in the late 1800's-early 1900's.
I don't know how most inspectors here who inspect houses with Crawlspaces and Basements at just about every property can make any money at the prices they charge. But the problem is not with any particular group, the profession in its entirety.
Its like inspecting another complete floor of a building with more things that can be wrong than just about any other portion of the building.
I would think $675-$875.00 for a 2000 sf house would be a fair price, but from what I have seen through the years they charge less than we do for a slab on grade, pity really.
Old 12/22/10, 5:32 PM
I now understand why many inspectors are doing commercial and IR.
The time involved in the shacks is not anywhere near as prosperous.
Maybe one day I will have the smarts to do the big buildings and get properly compensated for my time.
I figured today a 1200 sq. ft house would be a piece of cake. I figured wrong.
Old 12/22/10, 7:27 PM
Robert Ernst Robert Ernst is offline
You are allowed to insulate over k&t just not encapsulate it. Foam type insulation was the exception so that's probably why they used the beads.
Insulating Your House from CMHC mkyriacou Canadian Inspectors 10 2/14/10 3:50 PM
Basement vapor barrier jfrederick Interior Inspections 10 2/14/09 4:54 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 4 1/22/07 12:24 PM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 3:38 AM
