Tab M. Wilcox is a non-member guest and is in no way affiliated with InterNACHI or its members.
Okay, got called out to a condo which was occupied and saw something I have never seen. The bathtub was full of dirt. It appears that the dirt was built up behind the wall, and eventually the weight of it pushed the drywall in. Observed damaged drywall and dirt in an adjacent exterior storage room. I think it may have possibly been caused by Gophers from the field that is right next to this side of the condo. I saw signs of recent mounds in this field. I think they may have burrowed under the slab and got under the tub through the pipe opening in the slab. I do not know why they would do this or exactly where the huge amount of dirt came from. If anyone has ideas, please share. Thanks. Unfortunately I cannot post the unbelievable pitures I have....
| Find an InterNACHI certified Illinois Home Inspector (and anywhere else in North America) |
Let's see them. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Call the greens keeper from Caddy Shack.
Picture Resizer
This is a great little utility to resize pictures, and whole batches of them at once... Once executed, it puts another line in your "right click on a file" dropdown, saying "Resize pictures..." and allows you to choose the file size for batch processing. I've uploaded 800 X 600 to this message board successfully. http://www.microsoft.com/windowsxp/d...powertoys.mspx Enjoy, Steven Waskewicz Rest Assured Inspection Services, LLC. 719-510-7703 mobile all the time 719-495-7166 Fax. s_waskewicz@msn.com HVAC Lic. #10722 EPA cert.544143239730 www.restassuredinspection.com NACHIiid=NACHI06032370 |
I would like to post pictures, but in the Posting Rules box it says" You may not post attachments" I figured thats part of the new rules for non members....
Here we go....
Part 2
yikes!!!
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Depending upon the elevation of the soil on the other side of the wall this could very well be a broken water pipe causing this. The middle photo in Part 2 shows wet soil which is strange. There are also moisture stains in the tub as well. Is that tub below the exterior ground level?
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
that was caused by the rare gopherslingusmudus species.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
The condo is on grade slab. Yes there was a leak, but that pipe is at least 30 feet from the bathroom where this tub is located. There was an ~ 1/4" hole in the pipe about 18" below grade. We dug under the slab in three areas to see if the leaking water had significantly undermined the slab. We did not observe anything out of the norm. The mositure on the dirt in the tub was caused because the owner of the condo turn the mixing valve on. I failed to include the picture of the adjacent storage room. The dirt has come through the wall there as well. The owner emoved at least wheel barrows full of dirt from that room. I kinda ruled out the water leak because we saw know signs of undermining and the area I could see under the tub (from the storage room hole) was not wet. Thanks for any input you can give and thanks to Mr. Roberson for helping with the pics.
Dirt dobbers?
I was going to offer up "Termite Infestation" as a possibility, from your initial post. After eventually seeing your pics, and the amount of displaced earth, I'd be looking for something else. What... I have no idea.
Let us know what you finally come up with. |
| What are some of the marketing ideas that worked | wdevries | Canadian Inspectors | 8 | 4/16/07 10:32 AM |
| Ideas Wanted | jmckenna1 | Miscellaneous Discussion for Inspectors | 18 | 2/2/07 7:42 PM |
