Old 12/11/07, 4:21 PM
Dale Duffy's Avatar
Default New Air Handler for the garage--)))
This mornings inspection, somebody cut three roof trusses above the garage to install an Air Handler to condition the garage which also serves as a garage for vehicles of course....
Supply and Return ducts throughout the ceiling naturally.....
Oh...and the ceiling was quite stained from the missing drip pan and wrong condensate piping also, but we all know what water stains look like.............
Old 12/11/07, 6:50 PM
wsiegel wsiegel is offline
Default Re: New Air Handler for the garage--)))
In florida it is now against the building code to intall only one part of the system. If you replace the air handler, you must also replace the condenser unit.
Old 12/11/07, 7:37 PM
jking2 jking2 is offline
Yes, but the less this guy replaces - the better!
Old 12/11/07, 8:53 PM
Dale Duffy's Avatar
William...the system was installed as a package to specifically condition the garage.....
The condenser is just to the right of the exterior entrance door into the garage outside.....
Hanging from the copper tubing they cut a little short...I'll post the picture later.....
Old 12/11/07, 9:21 PM
Jeffrey R. Pope's Avatar
When the system is completely isolated from the living quarters, installing an HVAC system to service a garage is perfectly "legal" (from a building-code standpoint) and acceptable.
Sacrificing the structural integrity of the garage, however, is a completely different matter
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/11/07, 9:27 PM
Brian E. Kelly's Avatar
Hmmm, wouldn't the ducts need to be flame resistant Jeff? I do not know the answer,,,,,,,,,,,,,,,yet.
Old 12/11/07, 9:31 PM
Dale Duffy's Avatar
It was all the same Attic (garage-house-combo) Jeff.............
Old 12/11/07, 9:36 PM
Not if the system serves only the garage and is completely isolated from the living quarters.
Dale's system is not isolated. It shares a common attic, so it violates all model codes.
Many custom homes in my area are being built with garage HVAC systems. Apparently, people have nothing better to do with their money. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/11/07, 9:51 PM
Just as I thought.
Old 12/11/07, 11:26 PM
Charley L. Bottger's Avatar
I have two contractors here, and that appears to be their work how in the hell did they get in AR.
Here in Okla the The duct can share the physically location such as attic but must be separate system can not share supply or return.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 12/12/07, 7:19 AM
William,
Is not a southern thing, or if the unit is over 5, 10, 15 years.
thanks
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 12/12/07, 9:55 AM
I am not sure how well you can read it, but attached is the article
Old 12/12/07, 10:34 AM
David A. Andersen's Avatar
As I read it (the article, not the Code), it is not against codes unless the mechanical contractor can not show compatibility.
If you loose a compressor and want to change out the whole outdoor unit , it is OK if the equipment is compatible.
Changing an old unit with a SEER below current national standards could never be done as the new will never match the old.
Also, equipment Mfg.'s may void warranty if the unit is not matched.
Lets understand the whole thing before we start passing the word that it is "NEVER" allowed.
I have been calling out mismatched equipment for years. I don't need a code or law to do so.
Also, it should be noted that HI's do not perform system evaluation IAW our standards of practice. So if this is getting over your head, don't worry about it. You are not responsible for the condition.
Installing GFCI in garage with no ground cyezza Electrical Inspections 53 11/30/07 5:05 PM
Evaporative cooler in garage chellickson Inspecting HVAC Systems 9 7/23/07 12:08 AM
Garage ceiling & door header Al Barb Interior Inspections 7 3/27/07 12:07 PM
Garage Door Safety...No Reverse...Advice Please gliebig Exterior Inspections 33 3/17/07 7:28 PM
Garage fire rated wall jlybolt Interior Inspections 3 6/18/06 6:21 PM
