Old 1/14/08, 10:20 PM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Nice Set of stairs!
Hey hunny I just watched DIY lets cut these joists and move the stairs to the other side of the home. Better yet lets forget about properly supporting them!
sorry, I had some showing the full structure but the clients head is in the way in them!
Old 1/14/08, 10:36 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Nice Set of stairs!
So what are the joists at the top stair riser supporting now, that he would even lleave them there.
Old 1/14/08, 11:10 PM
cduphily's Avatar
The problem is he cut out the joists and did not re-suport the structure. I'm going to have to go back and take more pics. My camera did not enjoy falling in the snow prior to the basement inspection.
Old 1/14/08, 11:53 PM
relliott's Avatar
yeah I feel your pain as the sellers came home while I was getting a ladder for the attic and I noticed my camera LCD screen cracked.
Told my client and she said real loud in front of the sellers , gee what happened to your camera to see if they would fess up.
Oh well at least it still works.
Old 1/15/08, 10:23 AM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hard to tell from a photo but it looks as though the header is resting on the block wall and maybe the other side is a double joist?
If the span is within acceptable limits that install would be O.K. Although the lack of joist hangers is a problem.
Old 1/15/08, 12:04 PM
Michael Larson's Avatar
Not to mention:
the lack of a handrail and
that the "winder" portion on the stair does not appear to meet the 6" minimum rule of the IRC.
Old 1/15/08, 12:22 PM
Originally Posted by mlarson
Not to mention:
In looking at the "finished" side ,I agree.
In addition ,the stairs appear to be more narrow than the required minimum of 36".
Hard to tell from the photo though.
Old 1/15/08, 12:38 PM
It's hard to inspect from photos alone and wondered if it was wide enought too.
Old 1/15/08, 9:01 PM
cduphily's Avatar
My fault, poor photograph- the header is unsupported.
It ends at the stringers at both sides. What you see is another cut joist giving the appearance of the header continuing to the wall. Home owner was not home when I got there to take more pics ... at least the camera appears to be "ok" but I am getting a back up next week.
My fat A** didn't scrape the walls when I was walking up or down the stairwell, doesn't that meet acceptable criteria?
... Width was ok - 38" wide, No handrail and the winder was not to "minimum standards"
Old 1/21/08, 10:29 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Does the IRC or IBC list requirements for wood stairs? For example: Spacing between stringers, minimum stringer dimensions, support or securing methods at top and bottom of stringers (as seen in Chris's right-side picture), thickness of treads in relation to material type, face grains, slip-resistance finishes, etc. Is all that stuff for wooden stairs grouped or listed together somewhere in the code? (I can't find anything....)
Old 1/21/08, 11:24 PM
Barry Adair's Avatar
Ben,
Check this link
http://www.arcways.com/codes.asp
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 1/21/08, 11:32 PM
Barry,
Yeah, great....
But what about my question.
That document has nothing about the things that I asked about. Quoting me: "...Spacing between stringers, minimum stringer dimensions, support or securing methods at top and bottom of stringers (as seen in Chris's right-side picture), thickness of treads in relation to material type, face grains, slip-resistance finishes, etc..."
Old 1/21/08, 11:57 PM
Joseph Hagarty,  CMI's Avatar
In Pennsylvania, (if built and/or permitted before July 2005) the stairs most likely meet code.
Sad but True.
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 1/22/08, 7:49 AM
Here Ben, maybe this will help.
http://www.pacificwoodtech.com/pdf/P...irStringer.pdf
Marcel
stairs and railings cwillick1 Exterior Inspections 8 6/12/07 10:56 AM
Stairs required? jmichalski Interior Inspections 18 3/5/06 5:47 PM
Thank you ITA Denver for a nice evening! gromicko Miscellaneous Discussion for Inspectors 3 2/23/06 10:59 AM
