Here is the subject; New construction home with a ceramic tile shower and a fiberglass pan.
During a recent inspection of the home it was found that no caulking had been applied at the horizontal joint located between the shower pan and the shower walls. As typical, I recommended they had this joint caulked before the shower is used. Now their builder is not only saying that they will not caulk it, but if it were caulked, the warranty would be voided. He stated that caulking it would trap moisture behind the tile shower wall covering. (It is ironic that this comes just a couple days after inspecting a 4 year old home with the exact same missing caulking, and with the entire sub floor rotted from the shower leaks. ) My experience is missing and/ or failed caulking in showers typically leads to water damage in some form. The absence seems to be begging for water intrusions, and movement of moisture through capillary action. BUT, I am trying hard to keep an open mind; and my question is; "Is there any application where it would be accpetable not to caulk this joint between the tiles and the shower pan?" Preferably a reference to an ANSI standard, or some Tile Industry standard of practice to back it up, or refute it, would also be nice. My intial research does not support the absence of caulking, but thought I would tap into the collective knowledge here at NACHI. Thanks. "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." Benjamin Franklin, 1759
Harold i believe your builder is just trying to snow you...i have never heard of such a warranty limitation..in fact i think the opposite is true ...failure to provide a consistent bead of water resistant caulk between tile and base could void warranty of drywall and structure behind same...jmho...jim
have him produce the document where it says caulking will void the warranty, he won't and common sense will hopefully prevail
if this is the only item stopping the transaction he did pretty good ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here's a site that shows replacement recommending sealant as the final step.
http://www.thetiledoctor.com/repair/fiberglass.cfm hth You can ask, also, for the maufacturers instructions (and warranty info). Here's some.. http://www.lascobathware.com/pans_lascoat.htm |
Well that is my thought.... just a way to get out of something so minor.
Nice one Barry.
Ya, I suggested that the agent have the builder show her (in writing) where the warranty would be voided if the shower wall was caulked to the pan. Obviously he will not be able to do so.
yep, wanna bet we can find more links about repairing leaking showers than caulking voiding warranties
I just feel like I have entered the "Twilight Zone", when I get feedback like this from an inspection. I wish I knew how to upload the pictures, because it is good for a laugh. The joint is mostly bare, but with some crumbling grout in places, that slopped over during the wall finishing. At least if the builder thought that this was going to be the finished product, then they would have cleaned the crumbling grout off. "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." Benjamin Franklin, 1759
Hi Harold.
I've been doing tiling and showers for 24 years, here's what I think. When you are using a fiberglass pan that has a small shallow "weep wells" to the left and right of the front of the pan..... Caulk the joint in question except for the wells. That way (hopefully) any water that may find its way down the wall runs behind the tile and discharges out through the wells. If the pan doesn't have those small notches or weep wells, it entire joint gets caulked. Hope this helps. Rick |
THE BUILDER IS RIGHT!!!!!
Roofing caulk should NOT be used in this area! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Moisture Management | mcyr | Exterior Inspections | 15 | 9/8/08 1:11 PM |
| VIDEO--Bowed Basement Wall, Cracks etc | john bubber | Structural Inspections | 75 | 7/21/08 6:25 PM |
| Fire wall | tyeager | Structural Inspections | 38 | 8/24/07 12:17 PM |
| Newbie here with a slab "standards" question | Robert Young, #3 | Structural Inspections | 17 | 4/10/07 11:48 AM |
