I had an interesting question posted to my website comment box today.
A man is asking if there is some kind of code that requires the builder to install any type of sound barrier. He stated that the noise from other units echoes throughout his place and was wondering if there are any requirements at all. I know how people now in days like the exposed brick and exposed floor joists and wonder if that may be the case here. |
There are requirements in the International Codes for sound transmission and sound reduction between separate living units.
Yes...definitely...probably....maybe...heck, who knows, you're in Chicago, right? See the attached 2003 IBC Section 1207. Now all you need are those two ASTM documents
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
I did find this....
http://www.chicagocondodirectory.com...-buy-the-best/ But thanks guys. Looks like the guy may be in for a headache. |
Improperly installed insullation (sound or thermal) does not "perform" to the manufacturer's specs. But, unfortunetly, the codes only describe what is required for use. Many good Architects, I have talked to, state that the builder changed their specs. Due to a loophole in the RE law, they are allowed to do so, sell the property and be blameless in court. Maybe the NAR should look towards licensing GCs Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
One word...Homasote!
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Many of these lofts are stripped down and can have this type of problem also, as they have exposed brick and plumbing pipes with no real inside insulation to dampen the noise. Trying to get the neighbors to do anything (like carpet) may be difficult once everyone is moved in. I suggested with my link included ,that it is most likely an association problem at this point. |
Thanks Scott
I made sure to save the link. Could be a good recommendation in the future. |
Insulation will make almost no difference. Sound travels through the framing. To reduce sound you need drywall hung from an isolating device like hat channel.
Kenton,
In many commercial buildings, sound barriers exist almost in the same manner as demizing walls; that is, double 3/8 sheetrock on both sides, metallic studs from deck to deck, and stuffed tight with fiberglass insulation. It worked quite well as a sound deadener/barrier. |
What's a dimizing wall? And how will those reading this post understand how your recommendation worked and mine doesn't? Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
It could be the floor boards,so you guys may be looking at too complicated an answer.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Open cell foam works well. Soft and sound absorbing. Sure, the studs or joists will transmit, but the vibration will be dampened by the foam. Works well in a couple of recording studios I have checked.
| 50 amp disconnect for 1600sf condo | kmccullough | Electrical Inspections | 5 | 4/10/07 9:49 PM |
| Condo construction | rboyer | Exterior Inspections | 3 | 7/6/06 1:45 AM |
