I was looking at a house built some time in the 1930's. Some of the original plaster walls and ceilings had been replaced with rock. One odd thing though. The ceilings throughout the house all had this rippleing effect where the plaster is sagging between between the joists. I'm pretty sure the ceilings were plaster. What could be causing this ?
http://www.nachi.org/forum/attachmen...1&d=1316274355 |
| Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Bad nailing.
Is that a popcorn ceiling? Bet they threw the drywall right over the old slats. |
In a lot of old plastered ceilings of old homes, the plaster sometimes starts loosing it's bond to the wood lath and starts sagging.
Always some with the bright idea to sheetrock it and use 3/8" drywall cause it is easier and light weight. When screwing to the lath, half the screws miss the lath due to the cracks inbetween and don't hold crap. The weight of the loose plaster will make it sag. Sheetrock ceilings over plaster on lath should have 1x3 strapping screwed to the ceiling joist and hold the drywall. That would be my best guess to the problem. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The ceilings were textured (no popcorn though) in some rooms. The others were flat with varring degrees of the same type of sagging along the uniformly spaced outlines of the joists, and kinda hard to photograph. When I pushed back on the a few areas they were solid, like plaster with a layer of rock over it.
Sorry meant Joists Thanks James for the heads up... Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 9/17/11 at 10:27 PM.. |
The following website has some good info on Transitional plaster ceilings.
http://estateplaster.com/CeilingCracks.aspx I have seen the after effects of this type of ceiling failure. The cases I have seen or dealt with directly, were all catastrophic failures (almost no warning, and the ceiling fails). |
Great Info thanks Jamie Much appreciated ... Roy
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Jamie thanks. I just spoke to Philip (who got back about an hour after I called him on a saturday) and gave he gave some me some insites as whats goung on with this ceiling. I hope he keeps adding to his site. Thanks to all here you've helped to cofirm my thoughts on whats going on with "pillowing affect".
John Rudy Advantage 1 Home Inspections www.advantage1homeinspection.com 908-806-6364 Quote:
I've seen them come down too...not exactly see them falling, but the remnants...it ain't pretty, someone could get killed....! Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
| Home Inspector law suit | rcooke | Canadian Inspectors | 0 | 2/18/10 11:48 AM |
| Coming soon. Free, online, fireplace and chimney inspection course. | gromicko | General Inspection Discussion | 15 | 12/14/09 4:19 PM |
| Vaulted Ceiling Insulation | rcooke | Canadian Inspectors | 4 | 1/22/07 12:24 PM |
| Ceiling Fans Question | jsieg | Electrical Inspections | 12 | 1/10/06 1:31 AM |
