The original handrail in this older (80+ years) home is 32" high. It is fall protection from 2nd to 1st floor. It is secure and has no signs of weakness.
Do I note this as a hazard (for lack of current height regulations)? Last edited by dpotts; 12/15/07 at 8:21 PM.. |
I would report that the elevation is 4" below current construction standards, but would not necessarily describe it as a hazard.
Jim King |
So if someone did "The Tumble"; could an inspector be found liable for not recommending ripping out a perfectly functional railing and replacing with
a new conforming one? Anything can happen, but how far does one go to protect one's *** as well as a client's? |
I would recommend replacement for enhanced safety.
Doug,
Are there other issues with the handrail? http://www.nachi.org/stairways.htm I advise upgrade to conform or relocation to current standards when I run across these. Depending on what is present. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Code Check says 34 - 38 inches. I would point out the differences to the buyers, put it in the report and leave it to them to decide what, if anything, needs to be done. If you start to point out everything in an 80 year old home that does not meet the standards of today, that will some kind of report to behold. I would not hyperventilate over 2 inches difference but it will help you sleep better point it out.
I'm with you at this point. But some electrical issues (GFCI's) need to be implemented. It seems a defensive and informing report would include
"replacement to conform for fall protection and reduce liability". But the "Historical Designation" in most communities would hang you. I guess I'm looking for the catch all to "leave it alone but don't sue me later approach". Thanks for your input Doug |
Even the spacing is tight (3").
Suggested report narrative:
"Guards should be constructed so that they prevent people from falling over them and prevent children from crawling through them. This guard violates an aspect of current code/standard/practice, as do many "historic" homes. The guard should be at least 36 inches in height. This guard is not safe. Correction and further evaluation by a professional is recommended." I wouldn't pull any punches. Tell it like it is in the report. Although, during the inspection, I would orally explain how I understand that probably nothing will/can be done easily to this component of the "historic" home to bring it up to code so that it performs well, unless enforced by the local authority having jurisdiction. |
HIs have a legal, moral and fiduciary responsibilty to inform the client.
We also have a resonsibilty to keep the safe. If they die or get hurt, they won't refer us BUT, we can only recommend. Write it like you see it and write it to help your client. If they don't listen to you, after you have explained it and WRITTEN it, its on them. You can lead a client to water, but you can't make them thirsty! But, I would contend, that the first responsibilty of a professional HI is to get your client to TRUST you. See here: http://deckerhomeservices.com/bottom_line.htm Take the time and form the relationship and get the client to TRUST !!!!!!!! you. To do anything less is not professional. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
"Although not required when originally built bla bla bla............. you may consider upgrading to bla bla bla...................."
Typically, registered Historic or Heritage (as they say in Canada) homes are under more restrictions (what color paints you can use, style of windows, etc), not less with regard to AHJs. Should the handrail break and have to be replaced, it will be more likely that it couldn't be replaced with a chrome handrail than it would be given a pass on it's mounting height.
Seems to me that if you have to update a Historic home to present standards, it would no longer be truly historic, but rather an imitation of an older home. It might make it safer, but it would lose value. I would note my observations, educate them of the current standards and wish them a Merry Christmas when I handed them the report.
Along with my report, I might want to remind the buyer that - at the turn of the century when the house was originally built - the average life span for an adult was 40 years. There are reasons for that.... James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
| Older wiring | dmacy | Electrical Inspections | 1 | 5/11/07 2:40 PM |
| older electrical....please help | Scott Schultz | Electrical Inspections | 11 | 3/9/07 12:33 PM |
| GFCI in older home | kheintzelman | Electrical Inspections | 6 | 4/14/06 7:28 PM |
