Old 9/15/11, 11:11 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Older Sliding door glass question
How do you know if the sliding glass door is
safety glass or not?
An Ounce of prevention is better
than a pound of cure :}
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/15/11, 11:25 AM
Robert Ernst Robert Ernst is offline
Default Re: Older Sliding door glass question
There should be something etched in the glass at one of the corners. Some can be very hard to read. Some times it helps to put something darker behind the glass.
Nevada Inspector of Structures #1730
Nevada Energy Auditor #30
www.homecsi.com
Old 9/15/11, 1:13 PM
Jeffrey R. Pope's Avatar
If the home was built prior to 1968, it's very unlikely to be tempered glass, but as previously stated, it should be etched onto the glass at a corner.
Safety films are "allowed" as retrofit applications in most CA jurisdictions. The film will also have a listing label.
If you can't find the listing, call it out for correction or verification.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/16/11, 12:00 PM
Thanks for the info. Jeff & Robert.
Old 9/16/11, 10:38 PM
Tim Spargo's Avatar
I've had decent luck shining my flash light in the corners of sliding glass doors and windows to confirm etching/label.
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 9/16/11, 11:54 PM
Nick Gromicko's Avatar
http://www.nachi.org/safety-glass-for-inspectors.htm
Find a Home Inspector
Older ducting..good air flow...question dnasser Inspecting HVAC Systems 2 11/5/10 9:24 AM
Wall heater older home....ducting question dnasser Inspecting HVAC Systems 1 9/21/10 12:48 PM
Answer to a common question about GFCI's jtedesco1 Electrical Inspections 4 1/12/06 9:29 PM
