Old 6/12/10, 1:17 PM
David C. Macy's Avatar
Default Open area at sub floor
Any ideas what this vent/opening is for?? I hope it is not for the 2nd floor dryer.
This is the sub floor in the basement and it is next to the heating system
The home is occupied and the dryer is in use, no lint around the opening.
House was built 2002. Colonial, basement.
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/12/10, 1:34 PM
mnahrgang's Avatar
Default Re: Open area at sub floor
Could it be the location of a previous dryer vent? Maybe there was a dryer in that location in the past, and they moved it to the second floor... Just speculating...
Mark Nahrgang
www.HeyMark.info
Old 6/12/10, 2:58 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Could it be a bathroon exhuast vent?? Or combustion air?
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 6/13/10, 4:26 PM
prichardson's Avatar
prichardson prichardson is offline
Please Note: prichardson is a non-member guest and is in no way affiliated with InterNACHI or its members.
could it be there to provide combustion air for heating system?
Old 6/14/10, 1:18 AM
Joe Funderburk, CMI's Avatar
It better not be for a dryer, with that corrugated foil material.
Just say you don't know the purpose for it and that it should be traced and determined to be an appropriate material for its intended use.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/14/10, 7:47 AM
The unfinished area of the basement was pretty wide open and I doubt the opening was for combustion air. The dryer was running above and I did not see any lint. (It still could of been the upstairs dryer)
I did document in away as Joe stated.
Thanks!!
Old 6/14/10, 11:53 AM
Gerry Pallotta's Avatar
Gerry Pallotta Gerry Pallotta is offline
Send a message via Yahoo to gpallotta
Possible venting for a future grow op.
Old 6/14/10, 12:11 PM
FYI. One of the things I do in all my inspections is attempt to determine the discharge point for the dryer. If it vents vertically, I let them know that and advise them to check its function routinely. If I can't determine the discharge for the dryer, I say that and say it should be traced. I state whether it vents into the crawl and out the wall, directly out the wall, vertically and out a wall, etc. I state the type of material for the duct, if visible, or otherwise state it wasn't visible.
When I 1st started out, I had a call back about a dryer duct that had come loose in a wall and had caused a mold issue. Of course it wasn't my fault because it wasn't visible. But since then, I just try to let the client know how the dryer vents.
Theodore Roosevelt
Joe Funderburk, CMI
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
Floor Collapse jbushart Miscellaneous Discussion for Inspectors 0 8/4/07 7:09 AM
Ill inspector 2nd floor laundry floor drain? ebethel Plumbing Inspections 1 7/18/07 9:59 PM
