Old 6/30/06, 10:20 PM
Default Permanently elevated moisture levels beneath basement slab: why?
Every once in a while, usually in basements, I happen onto situations in which the surveymaster picks up moderately elevated moisture levels over a large part of the basement slab. It fluctuates, but always looks a little high. It's been dry here even for Colorado.
I'm thinking that it's just a high water table and some moisture is wickingup to soil levels close to the basement grade. Any other ideas?
This is not in the mountains but on the plains below the foothills.
-Kent
Old 6/30/06, 10:27 PM
rwand1 rwand1 is offline
Default Re: Permanently elevated moisture levels beneath basement slab: why?
Unless there is a vapour barrier below the concrete floor you will always have water vapour migrating up.
Old 6/30/06, 11:11 PM
Roy D. Cooke, Sr's Avatar
My home sits on a knoll The down spouts discharge are at least 8 feet from the home or more . The dirt is well sloped away from the home .
I have a garage on on side that extends away from the home.
My deck on the rear is closed under neath with steel roof taking the water away 12 feet from the home .
I put in a sump pump down 20 inches below the cement it seldom runs .
Yes there is also 4 inches of gravel under the floor .
Guess what I have elevated moisture reading every where in the cement so I just bought a dehumidifier to make sure I do not get mould any where .
I think I know what to do and have tried all I can and as Ray says no moisture barrier you have dampness .
Oh yes I have weepers all around the home I also dug down and put in a dewatering sump out side .
This is like a well down below the weepers by 18 inches again seldom does it ever have water in it .
Industry is the only place I know that they put down heavy plastic before they pour the floor.
Roy Cooke sr. . RHI Royshomeinspection.com
Old 7/1/06, 7:11 PM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
The house could also be built over a spring.
Cheremie
Old 7/1/06, 7:33 PM
Cheremie
If that was the case why would the (Oh yes I have weepers all around the home I also dug down and put in a dewatering sump out side .
This is like a well down below the weepers by 18 inches again seldom does it ever have water in it .) not have water in it ??????
We got much rain in the last two months some days over two inches ???
Roy Cooke sr
Old 7/1/06, 8:47 PM
Barry Adair's Avatar
Elementary physics and building science: water vapor moves from hot to cold, lowest point is coolest point, naturally occurring migrating water condensates or settles at basements or crawlspaces.
I once read that an average family of 4 produces over 17 pints of airborne moisture per day through breathing, bathing, cooking…didn’t know if that was per person or entire family.
Try these for further info I’m not a scientist or physicists hell I cant even speell it:
http://www.buildingscience.com/sitemap.htm
http://www.fcs.uga.edu/pubs/current/B924.html
IMHO:
It's a bad idea to pour a slab anywhere without vapor barrier, for a number of reasons.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 7/1/06, 9:06 PM
Barry that Building Science Corporation is a great link, thanks. -Kent
Old 7/1/06, 10:00 PM
phinsperger's Avatar
Kent,
I also have a Survymaster and the measurments in the search mode (not using the pins) will give high readings on concrete or stone. Maybe its picking up some minerals that conduct RF frequencies, I don't know but I do not even bother using it on any flooring surface that sits directly on a concrete slab.
Old 7/1/06, 10:08 PM
Just tried it here in the office with the same results, Paul. I've also gotten high readings (in search mode) on tile floors above poorly ventilated, tightly sealed crawspaces.
Do you ever actually use the remote probe attachments for anything? I don't find much use for mine.
Old 7/2/06, 12:28 AM
I have never used the remote probes but I carry them just in case.
Old 7/3/06, 3:08 PM
William J. Decker's Avatar
I see this all the time, around here. The slab is underground and cool. When humidity in the house air hits it (in summer or winter when the humidistat is set too high) it condenses.
I have seen many new houses where the owners put down carpet, directly on the slab. Within a few months, they smell a musty smell. Sure enough, the underside of the carpet is damp. No cracks or seepage, just plain condensation.
They are always real angry that they wasted money on the carpet. I put in my report boilerplate the recommendation that the slab be covered with plastic before putting down carpet of flooring. Don't want to get sued for their mistake.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 7/3/06, 9:53 PM
Generally, vapor barrier is a term often used when discussing humidity (or vapor pressure)where vapor (eg water vapor) is prevented from moving between discrete spaces or volumes.
You should install a thick, cross-laminated, high-density polyethylene vapor barrier under the concrete slab when building a house. Concrete keeps out most liquid water when used as floor, but it is porous, so some moisture will always wick up and transpirer into the air. Here is the general sequence of tasks:
Excavate for footings, walls, slab, and sump.
Pour footing, Pour walls, or build concrete block walls. Include foundation vents in the walls.
.Install plastic sump in sump hole.
.Install a thick, cross-laminated, high-density polyethlene.
.Install a built-in-perimeter drain to divert water away from the wall. (Even with the vapor barrier, water will often work its way around the edges of the slab and the vapor brrier. The purpose of the perimeter drain and sump pump is to collect this water and pump it away from the house.)
.Install and apply cruched stone on top of the polyethylene. This channels water to the perimeter drain and sump.
.Pour the slab.
It is constumary to see some sweating on a concrete slab at times, which is due the temperature differrential and Dew Point Levels.
Ventilation of the basement area would help elliviate some of the sweating scenarios.
For those wishing to apply flooring materials on their basement floor, the majority of flooring manufacturers have instructions limiting installation of the flooring material if moisture emissions exceed 3 pounds per 1000 sq. ft. of concrete per 24 hours.
Hope this helps.
Marcel
Old 7/4/06, 8:49 AM
Keep the basement windows closed during hot humid weather. Saw a basement the other day concrete floor was wet at wall. Hot and humid outside and basement windows were open above the area that was wet. The upper wall (drywall) was 63-65 degrees F. While the concrete floor was 53 degrees F.
Old 7/4/06, 11:06 AM
I agree with all of the posts regarding moisture wicking up from the slab. However, the Surveymaster that was refered to in the original post will indicate high moisture on even the dryest of concrete.
Old 7/4/06, 11:50 AM
William, do you put this in every report where the home has carpeting, just homes in which they mention replacing it, or in every report because any home can be carpeted?
something else to chew on john bubber Structural Inspections 662 1/31/12 2:33 PM
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 7:45 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
