Fireplaces in the basement and living room (shown) both had normal flues in this big masonry chimney.
Main floor- on the kitchen side was what looked like a two-section pizza oven, but the lower and upper, although they both were lined what looked like firebrick, were not connected. The upper oven had what looked like an 8-inch flue, but there was no smoke shelf and looking up into it, it curved away out of sight about four feet up. Can't build a fire below to heat the upper section 'cause there's no flue. No reason to buld a fire in the upper section, 'cause with no smoke shelf it'll smoke like crazy, it wouldn't warm the lower section and there's no place to put food if the thing's got a fire in it. Each fireplace had a little vent on the side of the firebox which had a sliding cover. The chimney partially terminated on the second floor and two three-inch vents were visible. Think these vents were somhow routed around the pizza oven thingie to heat the firebricks/oven? Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
I'd be scratch'in my head too Kenton!
Is this a very old chiney structure with a newer building around it? Is also notice the motar does not match on the CMUs pictured as if it had been modified. I have an old smoke house/bread oven on my property that they used to build a fire in the bread oven portion to heat the clay domed area and then rake out the coals to bake the bread with the trapped heat. It has a door to the oven portion. It was built in 1865 or so by German settlers to this area. |
This home was built in 2000, Michael. The firebox vents were located in the side of the firebox about a foot off the bottom of the box.
afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
unconventional construction - refer to a pizza oven maker person
could the lower "oven" be a wood storage area. maybe lined with firebrick because that's what they had? |
I would call for a level II chimney inspection in anyway but let me speculate.
The 8" flue from the "pizza oven" is used as a charcoal grill flue or for a hibachi grill. Should vent fine. Is there a damper on the 8"? The sliding doors could be for combustion air to each fireplace. And the sliders would permit it to be closed off for each when not in use. My opinion for fun and thought only. |
You didn't see any "Mexican Rivera" magazines laying around did you?........ ..........................
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I have seen some thing similar but the owners only used for storing fire wood.
| Electrical Questions - Please help | Adam Demarco | Electrical Inspections | 8 | 2/25/07 9:59 PM |
