| Interior Contains discussions about the interior portion of a home inspection. This includes stairs, walls, floors, ceilings, smoke detectors, et cetera. |
Al Barb is a non-member guest and is in no way affiliated with InterNACHI or its members.
Am repairing an old house and have question about attached garage wall.
House did have sheetrock on both sides of studs of house/garage wall. All exterior walls are currently open so that I can install insulation (had none) and replace outdated wiring. Heard a suggestion about mounting 3/4" plywood to garage side of shared wall to facilitate easier mounting of shelves and hooks for tools and such without having to locate studs. I also like the idea of providing a more solid surface between garage and home. (ie., Burglar or nailgun could easily pass thru two layers of drywall). I assume the plywood would have to be covered with 1/2" drywall. Also understand that the firewall either has to extend up to roof or simply cover the garage ceiling. My concern about taking it up to the roof is how it might affect attic ventilation. One of the gables is located above the garage ceiling. Thanks, Al |
Here's an illustration for proper fire-proofing in a garage... "Click to Enlarge" Attachment 9154 Last edited by dvalley; 10/7/07 at 5:42 PM.. |
Mike Smith is a non-member guest and is in no way affiliated with InterNACHI or its members.
Garage ceiling only has to be 5/8" X if living space is above it.
pdoane is a non-member guest and is in no way affiliated with InterNACHI or its members.
- Min [1/2" IRC] {5/8" UBC} gypboard on garage side of walls common to house.
- Min [5/8" IRC & UBC] gypboard on garage ceiling common to house. Best check local code adoption prior to work to insure your work is for not. Last edited by pdoane; 2/15/07 at 2:13 PM.. |
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Evaporative cooler in garage | chellickson | HVAC | 9 | 7/23/07 1:08 AM |
| Giant hole in the garage firewall for HVAC VENTS | mpeterson | Structural | 14 | 2/3/07 6:54 AM |
| Garage Firewall | jfunderburk | Structural | 19 | 4/9/06 8:23 PM |
