Master Bedroom door leading outside with signs of water
intrusion....Southern calif. not too much rain. Thinking it may be sprinklers pointing back at the house ? The house is 4 yrs old empty foreclosure.... ![]() ![]()
| Find an InterNACHI certified New York Home Inspector (and anywhere else in North America) |
Possible causes of water damage??? WATER
I'm in the east coast so I always recommend storm door installations when they are missing.
Do you have an overall exterior image? |
It looks like there is no exterior casing from what little i can see of that door...that would sure cause damage like that...
I agree. With that visible opening at the jamb I would say the water is entering at the wall, not the threshold.
First picture looks like a replacement sweep was installed. Does the door still have the original sweep that comes installed under the door panel. This may be an issue.
Do you have a picture of the top of the door? I will bet wood casing abuts the stucco without proper flashing and/or sealant. The wood side jambs abut stucco and are not sealed. You can see light in picture number 2 where the weather strip is incomplete.
************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
![]() I gave him my opinion on this. |
| What might cause this many cracks? | bhamilton | Structural Inspections | 15 | 2/25/09 12:44 PM |
| Water Damage Dilemma | dkraemer | Legislation, Licensing & Legal Issues for Inspectors | 13 | 2/4/09 8:35 AM |
| How to prove tree damage to water main without digging. | Jake Boen | Plumbing Inspections | 11 | 6/4/07 12:33 PM |
