Hey Gang
Does anyone have a larger picture of the gold colored pellet form vermiculite. May have run into it in a foreclosed property attic and wanted to CMA. I will send a picture when if I cannot confirm...hoping y'all could help thanks |
| Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America) |
Lyle,
There is a free vermiculite insulation course offered by INACHI. Look under educational resources. |
Lyle,
INACHI offers a free course on it with pictures. If you look at the menu on the left under Education, Education Resources, and then scroll down you will find it. Rich |
does it have a spongy texture to it. Larry the pictures you sent are great and look exactly like what I have but, it has a spongy type of texture most minerals I know of do not have that feel.
you guys are the best |
Vermiculite is light weight and I guess could be described as spongy. The spongy aspect of it is why it was used for insulation. If it were rock hard it could not insulate. It is also used in potted plants to help keep the soil loose and retain water. If it is in the attic you are looking at, wear a mask to protect yourself. It contains asbestos in the vermiculite itself.
dbolduc is a non-member guest and is in no way affiliated with InterNACHI or its members.
Exploded mica.
It contains asbestos if it was mined in Libby, Montana. Only lab analysis can verify if it contains asbestos. Don't make a fool of yourself stating it contains asbestos if you haven't had it analyzed by an accredited lab. Analysis is cheap.
Linas is correct. Here is an image from a recent inspection.
'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com Last edited by mkyriacou; 10/17/09 at 1:02 AM.. |
Linas,
I overspoke. I agree that all vermiculite does not contain asbestos, but since you do not know this at time of inspection a mask should be worn for the inspector's protection and I think the client should be made aware in the report that vermiculite insulation appears to be present and it might contain asbestos, it should not be disturbed, and that only further analysis by a lab can confirm asbestos being present. |
Therefore, even the EPA states that testing is inconclusive. And that if you have vermiculite insulation you should simply assume that it does contain asbestos. The reason behind this is because, since not all bags were contaminated, the bag that is in the back of your attic could have asbestos, but the bag next to your scuttle might not. If you test at the scuttle, and it comes back negative, you then live under a false premise that the home is asbestos free. Certainly if the test came back positive you would know for sure it is there, but a negative test doesn't really tell you anything. BTW, quit playing with it and "squishing" it. That texture comes when they heat it, and it "pops up" like popcorn. That's what makes it a good insulator. The EPA says to leave it alone and don't disturb it. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
I found an attic full of vermiculite on a recent inspection.
Did all i could not to disturb it and make it friable. I reported on the possibility of asbestos fibres contaminating it, recommended it was not disturbed at all. Provided a link to EPA page. Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
Check this site out, great for vermiculite http://www.thescottlawgroup.com/zono...tion/Home.html
J.Szczesny 4 Seasons Home Inspections Washington State Inspector # 711 800 5th Ave #101-385 Seattle, Wa 98104 (206)391-0285 online @ www.4seasonsinspects.com email @ info@4seasonsinspects.com toll free cal @ 866-512-9972 "For the best protection, get the right inspection" |
Good site for vermiculite!
Harold J. Lowe C.M.I., C.C.I. Eagle-Eye Healthy Home Inspections Sharondale Academy of Home Inspections www.healthyinspections.com harold@cannachi.org haroldjlowe@hotmail.com home-905-576-4337 cell-416-912-0852 CanNachi Director of Education Board Certified Master Inspector Certified Infrared Thermographer Pro-lab Certified Mould Specialist IAC2 Certified Indoor Air-quality Consultant Certified Commercial Inspector Toronto/Durham/Kawarthas Proud InterNachi Member # 06091197 |
| Vermiculite Insulation Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 3 | 1/10/09 8:43 PM |
| Vermiculite as attic Insulation | Chris Soti | Canadian Inspectors | 12 | 1/18/07 7:18 AM |
| Vermiculite insulation testing | tflaro | Canadian Inspectors | 19 | 11/10/06 10:19 AM |
| Vermiculite Insulation | cbarrows | Canadian Inspectors | 5 | 8/8/06 9:39 AM |
